Adding a Powered Subwoofer
Bencher
I have a 2016 SLT Sierra with the Bose sound system. The system sounds great but I would like to add a little more bass. I installed a Kenwood powered sub in my previous truck (Silverado) and want to do same in this one. However my research on this subject is revealing that this may be difficult with this Bose system. I noticed that the Kicker system for GM trucks 2014-2016 specifically says their unit will not work with with the 6.2 motor and Bose system which is what I have. Anybody have an idea why not and what does the engine size have to do with it? Thanks in advance for your input.
You may check and see if you have the noise cancellation system in your truck. As I recall, that's the main thing. I don't know that it would prevent you from putting in a sub though. It just might act a little funky if it gets the cancellation tones pumped through it.
From the topics I've looked through my general understanding is that the noise cancelation would have to be disconnected/disabled.
I think the ANC uses all of the speakers so there probably is not a clean input to be found. Not sure but disconnecting the mic might work
I had the same issue.. I have a 6.2L Denali with Bose. The active noise cancellation has 3 sets of microphones that are difficult to isolate (my dealer guy was trying to help and could not figure it out). I added a JL Audio sub and found a a mention on this forum to cut a specific purple/blue wire (crankshaft replication wire - it is thought to be what sends the rpm amounts to the amp to activate the noise cancellation) in my passenger side back door bottom sill to disable the noise cancellation. I don't notice that it is not even active but no matter how you connect up the sub you will have interference with the new sub if you don't disable. I will see if I can find a picture and post as well.
Sent from my Note 5 using Tapatalk
Here is the shot of the violent blue wire and it has part of the name of the original thread that I found it in. Good luck on your install.
  • 1 year later...
I did not lose any of my other items/functions (been running 2 years now) ... To be honest I did not notice a louder sound in cab with or without the stereo for me.. I should note I do have CAI and Magna flow Muffler (removed stock muffler, flapper) so I have a little more engine and exhaust noise purposefully. When cruising 70 mph though I am super quiet. I was surprised.
Sent from my SM-N950U using Tapatalk
Thanx for the info. Do I tap into the small wires coming from the head unit going into the bose amp to connect to high level input on new amp for a signal?
  • 2 months later...
On 11/28/2018 at 12:48 PM, super241 said:
GMC_SD_Ult_16
where did you hook your amp in and what did you use to convert to RCA leads
My sub amp has high-level inputs that were tied into the front speaker wires at the factory Bose amp. My sub amp also has rca pass though capability. I have a second amp and sub sitting in the corner and will install once I build my new custom enclosure.
