Put it back to stock, it's that simple. Why in the world people change the suspension/steering geometry and tire size and don't expect problems is mind boggling.
Computers do everything but steer for you, any deviation from stock and you're playing with fire.
Years ago before computers, sensors and specialized computer diagnostic equipment you'd buy a load of hockey pucks for under $20 and lift the Blazer without an engine light or a visit to a dealer.
Now you play with a computer saturated vehicle basically designed for use as a single height "rock and manure hauler" and try to get it to do something it was never designed for and pi$$ off one or more sensors feeding into a million lines of computer code (with thousands of lines of undiscovered errors) designed by dozens of programmers half way around the world and wonder why something unexpected happens. And don't blame the dealers either when they can't fix it because if the computer doesn't give the mechanic exact information related to a known problem, they have no clue what the heck is going on.
An excellent example of how screwed up the whole damn system is, is to take a look at a few items in monthly issued GM pubs that advise mechanics on emerging problems not listed in anything they currently have for reference.
http://www.sandyblogs.com/techlink/
Just look at some of the crazy crap going on related to diagnosing problems using the Communication U codes.....sometimes a steering assist failure can be triggered by a coolant temperature sensor, sometimes a 37% drop in speedometer accuracy if you shift in gear with your foot on the accelerator, etc. etc.
Alignment fixed my issue. I did see it kinda flicker when I took a pretty sharp turn getting onto the highway though.
Mine has been doing it more frequently since I switched to 275/65/20 tires. I can't see any kind of rub except for on the wheel liner at full lock. I just finished installing fox 2.0 shocks after getting rid of my leveling kit. Going to be doing an alignment Next Week and see if the issue subsides.
My 2014 1500 Silverado 4x4 has the same issue. The ABS kicks in at low speeds. The stabilitrac and abs lights are constantly on, and the annoying beeping sound activates when i hit a bump with the right front wheel. I removed the front wheel speed sensor and noticed it had metal shavings on the tip. I cleaned it and the issue was resolved. However, 3 weeks later i returned to square one. I believe the wheelhub assembly has gone bad. Does anyone know if this is covered under the powertrain warranty?
Ive pretty much accepted it and am planning on selling as soon as i can. Really sucks cause i love the truck otherwise.
No, the hub is not included in the powertrain warranty, and depending on your dealer/customer relationship, it is doubtful it would get covered under bumper to bumper either. It is classified as a wear item and unless a visible defect is present or premature failure they most likely would tell you to shove it.
Back on topic, how bad is everyone's TCS/SCS acting up? My 2015 will only do it when near full left turn lock at speed. In 27,000km (17k miles) it has done it probably 5-6 times. I never noticed it before the big tires and level. Definitely not the biggest annoyance. I will take that any day over the issues my 2014 has.
Sorry to bring up an old issue but was anything ever found on this my truck is a 2015 Denali 1500 5.3 with a 6 in rc lift with the stock magnaride shocks on 35s I doubt its my lift but since I've had it lifted for 4 months and have put about 14k miles on the lift and it just started doing this last week as well as when I brake it wants to go left now looked at everything below and everything looks normal
Figured it out ignore my post
Edited by joeg45
What was your fix?
What was your fix?
Went back under checked every bolt with a pry bar and wrench found my driver side upper control arm bolts just loose enough to move with a pry bar and some force. Aligned it and tightened them down now I can take all the curves I want and stabilitrak hasn't kicked on once since
I have a 2013 GMC Sierra 1500 with a 6" BDS Lift. I also have Stabilitrak issues. I have been through the same trials as many of the other users have described. Tire size reprogramming, multiple alignments, Steering sensor zero, different tires, different wheel offsets, etc. I even tried changing the mounting of the sway bars to limit roll. I started out with a RCD lift and after fighting with that company for months they offered me untested replacement spindles that I found out they were getting from BDS. Instead of continuing with them I took the lift off and put on a full BDS lift. The results were better but unfortunately I still have false positive activations of the Stabilitrak.
I believe this to be a problem with the programming in the EBCM (Electronic Brake Control Module) not to be confused with the ECM (Engine Control Module). The ECM can be easily reprogrammed with any number of programmers. Changing tire size in the ECM only effects the speedometer. Unfortunately there is not a way to get into the EBCM that controls ABS, Traction Control, and Stabilitrak. As far as I know a programmer for this has not been made other than what the Dealer has. Even then, the programming for these are only stock preloads and of course the Dealers wont touch this issue.
For a while I was turning off Stabilitrak by holding the TC button for 8 seconds each and every time I got in the truck. I later found a product made by KP Technologies. It is the FM-20 and they call it their Flexible Memory Module. This unit turns off Stabilitrak for me every time I get in the truck.  I connected this to my TC button harness and if I turn off Stabilitrak by pushing in the TC button this module remembers how long I held in the button to do this for me every time I start my truck. This way I don't have to pull the ABS fuse and I can have Traction Control and Stabilitrak both off and still have ABS.
I am still hoping at some point someone will find or develop a better solution.
  • 3 months later...
I have a 2015 Silverado 1500 lifted 7.5 inches with 35 inch tires. I am having the exact same problem except mi is when you turn either direction. It's been to the dealership 2 times the abs wire going into the hubs have both been replaced. The have even changed out the electronic brake control module cleared all the codes and it is still doing the same thing. They are now telling me the module is reading the truck is leaning so much in a turn that the breaks are engaging to prevent it from rolling over. Personally I think the are full of shit. I contacted Ruff country they said to recalibrate the speedo and it should solve the problem but we will see.
    • They are talking about adding more tax to our fuel across Canada by the labour day time frame, its the carbon idiot tax increase on top of the pile of fuel taxes we already pay thanks to the WEF dictatorship running the country. 10 cents per liter on gas and 4 cents a liter on diesel I believe is what was said. That is a huge amount of a tax increase as its another 38 cents equivalent to a US gallon of gas. The reason our fuel is higher than the states already is because of of the high taxes they have imposed on fuel.
    • This is just a thought as I can't claim this is the correct thing to do but will suggest it and you can decide if its something you would try. First round up some electrical contact cleaner spray as they at least claim its not supposed to damage the components ( brake cleaner depending on the type is a real destroyer of plastic etc ) and to use that to assist to clean out any grime from the pins as well as the mechanism by spraying and working the lever etc. Then my next thought is to use silicone spray lube and not on the pins but on the seal and the pivot assembly. It may not be possible to spray it on certain area's and have to use a q tip as Davestar mentioned to keep it from getting on the pins. Dielectric grease can be fine on some things but its easy to get too much on if not careful and then gunk things up and a possible risk of getting it on the pins or sockets. The silicone spray is able to get into a mechanical component to help lube and on surfaces its just a fine film to reduce friction such as that seal. Also it can be doused off with a good flush of the electrical contact cleaner the next time for a repeat of a "clean and then lightly lube" step process to wash off any dirt that had stuck to the exterior etc of the plug.   Free advice, yes. Good advice ... now there's the question mark !
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
