Is the hood fiberglass or aluminu? Also were you able to have the ram air route into the air box
It's metal. Yes I have a cold air intake so It worked out.
Thank you for sharing this information. Is it basically installing a hood from a 2500 on to a 1500? If so, is the fit the same or is there some modification required?
What does the vent do for the engine? Added HP or torque? Can you post a pic of what's under the hood?
Looks great. Just curious is the vent trim in something other then chrome?
Thanks
I'm not sure I didn't check I went with chrome because of my grill.
Yes that's what it is. And the only thing that was changed was the hinges and springs from a 2500. Other than that nothing else.
I mainly did it just for looks but I am sure it should help the engine get more air and more power. I don't have any pictures of mine from under the hood but this is what it looks like under the insulator.
Okay, who's gunna do it on a Silverado next??
On my to do list... I hope I'm the first
  • Like 5
This should help I found it in FB I just don't know what part numbers are for the springs and hinges. Also the part number here for the duct on gmc is incorrect.
    • Looks nice. I still have my 2000, 1500. Bought a 2025, 1500 for retirement. Feels solid. These trucks have a bad rap on the internet. My brother has a `24 1500, 5.3 with 52,000 miles. No problems at all. Mine hasn`t either but mine`s only at 12,700 miles. Have seen some of these things with 100,000 miles with no problems.
