Air Conditioning Inop
Spurshot
I drove my truck yesterday and needed the AC as it was 85F here. I was getting no cool air.
Today, I put gauges on it and got 0 pressures. I dumped a can into it and pressures didn't come up.
Checked the compressor. It (clutch center snout) turns freely. Too freely. Like put one finger on the face and turn it. Checked it against my Camaro. It takes a grasp of the clutch snout to rotate it.
Opened the system at the firewall/orfice. Clean oil and no debris (whew).
Put the vacuum pump on it for an hour, isolated it and it crashed to ambient in a couple minutes.
I'm thinking broken shaft inside the compressor.
Ideas?
Check for a cracked line just outside of the compressor in the tight bend. There's a TSB out there. If you have a '14 or an early-ish '15 and you don't have a brace between the compressor supply and return lines, it's very likely. On a related note, guess what happened to me last week! :)
Thanks, I'll check for that.
Can you do me a favor? Try to turn the compressor by hand. Just the front of the clutch. Mine just doesn't have any resistance. Feels like the shaft isn't connected to anything.
I saw a YouTube that showed a clamp/bracket that tied the hard lines for the discharge (high side) to the suction (low side) together as they come off of the compressor. None of the online parts diagrams show the new clamp.
Anyone have the new clamp part number? How about a TSB for this problem?
Can I impose on someone, maybe a few of you, to reach down and try to turn the front part of your compressor clutch?
Mine just seems completely disconnected from any internal parts. Like it was a sheared shaft. I can put one finger on the front of the snout and turn it.
Sorry, been out of digital range all day. Mine spins free. Just a tad bit of resistance. But line is visibly cracked. It's a hellacious spot to get to or I'd take pics. Also, it's cold :lol:
I looked at the lines as closely as possible with a mirror and strong light. I couldn't find cracks.
I'll pull the lines and inspect them out of the truck. But I'm just going to order a set of lines anyway.
Just a quick pressure check will tell you if you have bad lines. But if you don't have the brace, it's good money to replace anyways.
I vacuumed the system. It wouldn't hold a vacuum. I'm a bit worried it could be a condensor or the compressor.
I removed the compressor, all the lines, and inspected all of it. I don't see any cracks or indications of leaks.
I'm thinking maybe it's the condenser. I have to figure a way to leak check it, preferably in the mounted position. I'm thinking vacuum check it.
i would use pressure to check it, even the best gauges can have small vacuum leaks. i use an inline reciever dryer half full with oil and pressurize the system with 150 lbs shop air, most times you will hear the leak, i also put leak detection dye in every system after repairs are done
  • 1 year later...
On ‎4‎/‎21‎/‎2018 at 8:12 PM, Leo0916 said:
What did the problem end up being? I am having the same issue.
Wife is going to take our 16 Tahoe in under GM special warranty 17336-02 for the AC not working. Not sure if this TSB is for the trucks also or not, does not hurt to ask. On the SUV's it extends the factory warranty to 5 years or 60000 miles for this issue.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
