Donstar-I didn't mind it really with my stock exhaust. With my new exhaust when going into V4 it sounds aweful so I want to avoid that.
I knew this before the purchase of the MBRP so at the moment this is my cure to that farting sound when in V4.
I read what others have said but I am curious as to why you don't like your truck in V4 mode? You should only notice the change by the indicator in your DIC. Your truck has an abundant amount of power and it makes sense to reduce use when the need isn't there. I believe there is some stigma associated with running in V4 when we paid for a V8. I still feel the same way about driving a truck with an automatic transmission! If you're noticing any lack of responsiveness or power as a result of the technological advancement of AFM then your vehicle needs service, imo.
I'm with you on this one. I've often wondered why some don't like it as well. I never notice when it goes in/out of V4/V8 and if it saves some gas then all the better.
A casual read thru various threads on all the GM related pickup forums should satiate your curiosity on why many folks despise the AFM thing. My basic understanding of hrydraulic lifters and how AFM does its thing and how the motor oil that is used in that function is affected was enough to convince me that I didn't care for AFM. I didn't do my homework as I should have before buying the 1500 or I wouldn't have. But it is a non issue now that I went back to a 2500.
Edited by Cowpie
Some are more sensitive to their vehicles than others. Driving styles also vary. Does your 6 cylinder have afm?
More stuff in the motor to break, 300K miles on a 5.3 without internal work not likely.
Yes the 4.3 has AFM. I can often predict when I may expect to see V4 light up but I can honestly say there is no feel or sound that indicates the change. My 09 Sierra had the 5.3 with AFM and it wasn't noticeable but I also didn't pay attention to it until reading concerns about AFM on this forum!
I can hear the difference, and feel a noticeable shudder when it switches back to 8 cylinder. Quite possibly the V6 has a smoother operation than the 8 cylinder.
I have the 6.2 and honestly cannot tell when it moves in/out unless I happen to be looking at the dic.
need to bite the bullet and make the change to diesel
Before my Corsa it was harder for me to tell, but I could still feel it slightly and the flapper valve would chirp. Now with the exhaust it is noticeable both with the change in exhaust tone and along the power train.
I already own enough diesels. I go thru around 20,000 gallons of diesel a year. I don't want the Dmax in my pickup. I never have had a fondness for V engines anyway, and I will not buy a V diesel, I don't care who makes it. My 2500 only racks up enough miles in a year to justify one oil change per year, and my oil change regimen is every 6000 miles or one year. A diesel under those circumstances would be stupid. My 2500 goes for weeks between startups sometimes.
Edited by Cowpie
  • 5 years later...
On 3/23/2017 at 4:03 PM, Dexter10 said:
Hey all. I am new to the forum with a 2015 Sierra 1/2 ton. I installed a cat back MBRP system and love it. Except when in V4 mode. I knew this before the install and plan on picking up a Range AFM if I can find a cheaper used one. Until then I am driving in M5 mode unless above 60mph.
Will this do any long term damage? I have not been shifting with the button and have let the computer shift for me if that makes sense. I start off in M5 and let it do its thing. What are people's thoughts?
Anyone have a used Range?
Is there a max mph I should adhere to? When in L5?
I’ve spent most of my life pulling heavy from half tons to one tons. They when pulling would be in the next lower gear stick or automatic once transmissions had over three speeds. Once the engines got smaller and we got more gears it seems even empty they don’t stay in high gear long anyway. The RPM dance all over at the slightest incline. My CRV with the CVT transmission spends more time at 3K RPMS at 70 than 2K. Besides possible gas mileage hit and maybe more transmission heat that test would be interesting. Maybe you should start a thread. Something like who drives in the next lowest gear? What are the effects?
Edited by KARNUT
I have been doing this for about 2 weeks now, with no obvious issues, keeping my speed below 80mph, usually 75-76mph. My rpms usually range between 2200 and 2500 sometime s bit higher, but no engine whine that I can detect. I'll do a few more weeks and update. Thanx for the feedback
I have one car that is factory stock at 70 mph is at 4K RPMs in 5th gear it’s highest gear. It’s 22 years old.
Edited by KARNUT
    • Your safety is of utmost importance, @joshua1221, and we understand the importance of having all your lights working in your truck. If you have not already, we highly encourage you to bring your concerns to the attention of your local GM dealer. They are in the best position to diagnose your concerns as well as confirm the compatibility of the mirrors with your truck. Additionally, we would like the opportunity to explore any way we may be of assistance. When you have a moment, please visit: https://s.gm.com/support-request and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • - I like the outside but not as much as the Chevrolet.  They ICE'd the EV styling and it works, but I think exterior goes to Chevy on this one.     - SLE and SLT dead = Not.  Surprising.  Fits into the rest of the GMC lineup like this which (aside from Pro) matches the rest of the family.  Elevation, AT4, Denali.     - Interior.  Sophisticated Malaise era.  Why do I say Malaise?  Drawn with a ruler.  Rectangles everywhere.  Looks very premium though.
