Elite e2x vs. UPR Plug n Play
Anyone familiar with both systems and able to comment on which one performs better? Capacity with UPR might be an issue. Also mounting location for those who prefer the spare battery area. But, the OEM fittings must be great.
  • Replies 35
Duckfart, I like it. Nice to see another MN Twins fan. Was it Bert Blyleven who coined that term for the twins?
I have Elite Catch Can, mounted in the rear. I'm not sure what model Elite it is, I forget, but it works great. Thanks for the reminder to empty it, I just ran out and did that.
I like and have the Elite E2X and like it for the mounting options. What I don't like is the cheap hose that's used. Mine collapses under vacuum and makes noise.
The UPR has nicer hoses and OEM style hose ends. The single mounting option is a drawback since I don't like the master cylinder location because it gets in the way of the oil fill location (funnel must be used).
That being said both are great companies to deal with and very responsive.
I wonder which separates better
I looked in classified section and found mine. That's how I chose. There's one in classifieds now you might take a look at
So do I.
I like the fact that the E2 doesn't have that drain valve which could leak and the E2 can separates for cleaning access. The E2X and the UPR do not separate and have the drain valve. I believe that Elite has better hoses now too. The spring hose clamps that Elite uses are the same as some of the other stock hose clamps in the engine compartment and although they aren't the same as the stock PCV clamps, they do match others in there.
+1 for elite. I love mine
Most folks like what they already have - human nature. Did you choose it over the UPR for some reason or is it just what you got?
We never have issues with our drain valves leaking on our new systems as we switched suppliers, the only way to have a leak would be operator forgets to close it properly. If the drain valve is an issue you can always opt for a drain plug as many do and just use a 3/8" wrench and you can drain the system in a few minutes. I do prefer the drain valve and just add a nipple to the bottom with enough hose so it just drains into a pan under the vehicle is how I run my personal stuff. We will be adding a drain option on the website next week.
Joe
Thats exactly why I said that haha. Very biased opinion to be honest I havnt looked into the UPR unit too much, i was already sold on the e2x.
That's the deal. No one seems to have done a legit side by side. Basically you have two guys both saying their product is best. It's like being at the fair and trying to decide which barker has the better peeler gizmo. I'm probably overthinking, as someone suggested, but it's not an insignificant amount of money and I want to make the best choice.
If i remember tonight after work ill drain mine and post a picture of the gunk it catches. Its impressive. Not trying to undermine the UPR, I just havnt heard too much about it and was impressed with e2x reviews and the support/videos they had.
They all catch gunk. Which is the best gunk catcher?
In my opinion the can part is all the same. The nly major difference is the connectors they use. If 1 works better then the other I'm sure it's very minimal. Not even enough to notice. Put a picture of both on a wall. Spin yourself around and whichever you.touch first buy it
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle.    What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
