On 5/31/2022 at 10:31 PM, Jay Ratliff said:
2018 Silverado Custom Crew Cab L83/6L80E.
Zero Mods- Well, I did trim the tabs off of the lower front air dam to add a bit of approach angle after tearing one side loose on the deer lease.
187,000 miles as of 5/31/22
Failures to date:
* Water pump about 50k
* Transmission at 97k (covered under extended warranty, cost me an xtra $1k to get a crate unit instead of LKQ, so got a 100k warranty with the replacement).
* Hail Damage at 120k, replaced roof panel and hood, PDR multiple other dents.
* Water Pump about 140k. Went ahead and replaced t-stat at the time.
* Rear brake pads at 175k.
*Transmission a week ago at 187k, barely under warranty, no warranty on crate unit but no cost either. On my own in 9k miles.
Maintenance:
Oil change every 6k with Valv full Syn 0-W20 and Puralator Boss filters.
Trans service at 50k mark, both times.
Air filters as needed, checked every oil change.
On my 4th set of Cooper Discoverer AT 275/55/60's.
This weekend she'll be getting new spark plugs and wires, and full service, including rear diff fluid change.
Only three things nagging at me now.
One is a slight engine temp fluctuation, floats between 207ish up to about 215ish on occasion at hwy speeds, suspect the grill shutters, looking into mod'ing them. Modified the shutter system last weekend. Took 2 long blades and 2 short blades from each side of the assembly, leaving only those necessary for the motor/linkage to function. Temp swings have disappeared, sits right on 207 now, and transmission cools down faster on the hwy than it used to.
Second is prolonging the life of these JMBX torque-converter failure-prone transmissions. Thinking of the pill flip mod and possible trans tune.
Third, it almost feels like I have a motor mount failing. Feels like a slight movement in the drive train somewhere when I start from a dead stop, like it's taking up slack before power is applied.
Surprisingly, I am happy with and love my truck. I'm sure I'd be a little more grumpy if I'd have been out of pocket for two transmissions at this point.
Update: Currently at 260k miles and counting.
  • Thanks 1
231,2xx on my 2016................
  • Thanks 1
    DLZ
    DLZ
  • Who's Online   2 Members, 0 Anonymous, 568 Guests (See full list)
