Ruined ABS Modulator Block
My 2000 Sierra 1500 had 3 brake lines fail one right after the other, while i was driving, with the kids in the car. No brakes. Replaced all the lines, and didn't realize right away, but one of the flare nuts on the new line got started a bit crooked into the ABS module. I torqued it all the way down before i noticed, and crushed half the flare that is machined into the alum block.
These suckers are expensive. The ones that pop up on a quick internet search are $350. But none match the part number that is etched into the existing modulator. There seems to be a variety to choose from when searching my vehicle. There's at least 3 diff looking ones, with one looking very similar. Do i just pick that one?
Check your local junk yard for a matching abs module. Probably a lot cheaper too
Give member 15HDriver a shout via PM and he should be able to help you determine which ones will work.
Match the block with the correct pump you need.
One pump has pins on top to the module the other has a wire that comes off with a pigtail to the module. Disregard the part number.
You will most likely find the pump and block sold together with the bracket for the frame.
