Help me choose new wheels!
  • Replies 30
Go with the Alphas, that will set your truck off
Sent from my SAMSUNG-SM-N910A using Tapatalk
Between the 2, HOSTILE. XD have ran their course and far over played.
Never understood the black wheel thing, just looks like you've got really dirty wheels. Gun metal gray with that white truck would look great. IMHO, your stockers look better than any of those posted.
Good luck with choosing as I am in the same boat. I'm old school and love chrome, but thought I might branch out and get black milled. I am looking at the Fuel Diesel, but for chrome, I am looking at the Hostage, Krank and Throttle rims. Eenie Meanie Minnie Moe! lol How well do black milled hold up and how hard are they to keep clean?
I like the XD820s, as you can see I've got them on my truck, but with the machined face. I was originally gonna get them all black with the blue trim, but my wife overruled me and we compromised. :) I've got the BFG A/T KO2 tires, 275/55/20. Love how they ride and they're quiet on the road.
OEM snowflakes
or given the choices....sprocket
X2
Dont go XD or fuel or black, every one has that. specially teenagers. I teach at a high school, in the country, so there are a ton of students with trucks and all modded out and so many of the them have black xd rims. All the trucks look the same. And the worse part is the parents pay for all of it. haha but just my take on it.
  • 1 month later...
I just put on 20x9 fuel beasts, couldn't find any photos beforehand either, but I love how they turned out. Tires are 305/50/20 nittos and got a 2" RC level put on. Hope this helps.
Xd is out for sure. Some fuel still look unique. Methods are all the rage right now
could you take more pictures? I personally was wanting to get these for my silvy. Just deciding between 20s or 18s, i have the 2.5" RC level/lift, so I wanted to know if theres any rubbing and how it looks from the side. 33's should be ideal though I want 35s but I think Ill need a few more inches of a lift sadly..
What are the OEM Snowflakes that everyones mentioning?
