Signed papers today...
I signed papers today to buy a 2017 Silverado LTZ 2LZ. I managed to get a great deal and more than a fair offer on my 06 Titan. They have to try a locate and then possibly if they can't find one a factory order. Pretty stoked though. This will be the first domestic I've owned is 20 years.....
Welcome to the true Force.... :chevy:
2LZ? Hopefully they can locate what you want........
Pretty sure it's the 2LZ, it's the one below the High Country. I'm hopeful, they seemed confident but we'll have to see. With truck month on dealers may want to hang onto their stock. Anyway I know they will find something.
You are correct. 2LZ Z71 is what I have. Find a loaded one and you have a Chevy Denali. Only options you will not be able to get are the power assist steps and magnetic ride control. You will be very happy with that option package!
Welcome! It sounds like you will have a nice truck. Is there some flexibility in the paperwork you've signed in case your dealer finds a vehicle close to your agreed upon purchase?
What about the digital 8 inch driver screen? Pretty sure I have read the Denali has upgraded leather and 12 way power seats versus 10 on the SLT? That is a few thousand dollars in extras...
Tyler
Tyler
Thanks for correcting me. Maybe the original poster should think twice about what he now buys. Sorry for not bringing all facts to the post.
I'm sure they'll call me and let me know. They basically said they'd locate and if not do a factory order. The one sticking point I think for the locate is going to come down to the rims. I've went with the standard 18's, and from looking around the net it seems most 2LZs have 20's which is the option. Oh well....
Happy with the look and ride quality on 20's........ Going in I was like you, rather had 18's........
Yeah they do look nice. I have managed to find a few in Northern Ontario and Quebec, which makes sense given their need for snow tires and generally speaking terrible roads. Anyway maybe they will call me and tell me I have to pay for them or wait.........
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
