Gardit spray in bedliner....opinions or better options on grippy liner
Local shop is offering for the next month, this new Gardit spray in system from Reflex coatings for $349 with lifetime warranty. As per the manufacturer description, it's a more industrial coating intended for extensive use in contracting field and such but supposed to have very long lasting durability. My only concern is lack of grip as I've read it doesn't have the grip of say, line-x and the like?
Has anyone ever ran across this Gardit system? Or recommend a long lasting, low fade, grippy spray in liner? I have the factory drop in now on my 2014 LT.
Rhino :happysad:
If you want grippy, Rhino is the way to go. In my experience, LineX is the harder of the two, Rhino makes a really soft version for floor liner.
Give it a try and report back! "Grippy" is a quality with advantages and disadvantages! I recommend getting a GM bed mat to go with any coating you choose. It will give you a softer surface with the right amount of grip!
Now that I think about it, I could just get a spray in liner, and if I really find I need the grip factor, get a rubber bed mat.
