Thanks for the info, it was very informative.  Those DL3 Mirrors are pricey, so that will have to go on the back burner for now.
I feel like crap now that I realize have a lower trim truck with the SLE.   :)  Story of my life.
I add running board lights recently and wired them to the puddle lamp circuit with a little information help from @TinkeringFox and @pgamboa. They turned out perfect, and really light up the steps. I had previously done this mod on my 2015 Sierra using a very inexpensive ebay light that I tied to the dome light circuit. I like the puddle lamp circuit better for this purpose.
This is my 2018 Sierra.
This was the 2015 Sierra.
*Removed the pics so I don't spam the thread*
Would you happen to have a link for the lights you used?  Perhaps pictures of the routing you used for the wiring?  I'm wanting to make this the next mod I do n my truck and am just starting to research it.  This thread is helping me tremendously.
@Darmichar here are the lights I used https://www.amazon.com/dp/B01JUE9OLM/ref=twister_B07BWSJ9KY?_encoding=UTF8&psc=1. I cut out the installed switch and soldered the positive and negative leads of the switch together. I ran the power lead from the lights through the parking brake grommet under the drivers side floor. Under the carpet up to the BCM and tapped the puddle lamp wire. The ground wire for the lights I just ran to a frame ground in the same area of the Pbrake grommet.
Where and how did you mount the actual light strips?
Also assuming you tapped into just the puddle light wire with no diode mods, any chance you could see if the puddle light circuit still functions when the locator lights option is off in the settings.  I don't like my reverse light and hids coming on every time I unlock the truck.
Thank you @Grjfer, That makes perfect sense and probably just saved me a lot of research.
@Crazyjoker77 light strips are mounted to the lower rocker panels as close to the running board mounts as I could get them. They use the same 3M tape as vent shades and hood protectors have. No diod mod associated with the puddle lamps. I do have the cargo/reverse light diod mod.
With locator off the which is how I have mine, the puddle lamp circuit is active, as well as the reverse lights. No headlight though.
When you tap the puddle light circuit, do these lights come on instantly, or do they fade on like the interior lights do?
Edited by Darmichar
Good question. I will have to see next time they come on.
I’d love to see more pictures of your trucks with this done. I haven’t decided if I’ll do a “rock light” style light below each door or do a strip under both doors. Load up those pics boys!
Just got to in on this thread and would like to do rock lights. Would you tell me where to tap into the puddle lights? Can that circuit handle the load of four rock lights?
How did you get your reverse lights to come on with vehicle locator lights off? I want my reverse lights to come on but not the HIDs, but if I turn off locator lights, the reverse lights don't light up.
I ment to update this. I forgot I had turned the locator function on. So after turning it off, no lights come on till I open the door. Then it's only the dome, puddle, and my running board lights.
dang that sucks, lol. I was hoping the puddles would run independently of locator lights like i was reading here. Because it seemed like they would not but I was getting my hopes up :D
    Randy Ginoza
    Randy Ginoza
  • Who's Online   3 Members, 0 Anonymous, 1,916 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
