Does Chevy care?
i have a 2014 Silverado with problems. Set cruise control roll down power windows cruise goes off. Put on directional with cruise and try to switch lanes cruise shuts off stabil trak comes on sometimes ripping the wheel out of your hand. Turn the steering wheel with the air on and the fan slows down. this truck is dangeruos my wife won't ride in it any more. Took it to a dealer, can't duplicate it. Told them there was a voltage drop when this is going to happen. Figure they would try to duplicate a drop in voltage see what happens nope they put another 150 miles riding it around. Called main customer service number told them about what was going on looking for tech help. Her response was I will call the dealer and see if you can ride around with them. If thing doesn't get fixed a lawyer is next.
I'm a GM World Class Technician and I get nothing but problem vehicles like this. I've worked on a ton of the 2014's with random electrical problems like this. You know what just about fixes them all?.........Battery cables! I replace both positive cables and the negative cable. I bet you if a technician pulls some DTC's they'll find a bunch of B1325 in a lot of modules. The code will be a low battery voltage code. Basically, there is high resistance in the cables not allowing the full battery voltage to come through, so when a module gets around 9-10 volts instead of 12-14, it does crazy stuff. I would also change the battery a well. I'm almost confident this will correct the concern.
thanks justin,guys like you is what makes this forum fantastic. i copy and pasted that one for future reference . not to hijack a thread but could you tell me my truck constantly has these two codes U0073 and U0100 . the truck seems to run fine , i clear the codes but within two weeks the same codes come back
PM me so we don't get carried away on this thread. Year and trim model?
Thanks Justin i have been telling the service dept. about the problems start with a voltage drop but all they want to do is go for a ride.
Take it to a different dealer or just buy a new battery yourself. Worth a shot. The factory batteries are pretty bad with a very short lifespan.
On issues like this (where the dealer doesn't listen) I type up a couple of lines detailing the issue - "Customer says ..." and ask the service writer to type my words on the service request. At least that leaves a good record of the problem for future reference.
Do not make your wording too long or the service writer won't want to type that much :-)
Sounds to me like they don't have anyone that diagnose it. You can try another dealer, or call the GM customer care line. Or request a field engineer to come to that dealership. Nothing is more effective than saying "I'm leaving with you until it's fixed, and you want a loaner car" [emoji23][emoji23][emoji23]
  • 4 weeks later...
Taking the time to thank Justin. Convinced dealership to put new battery cables on my 2014 silverado (like you suggested )400 miles later and 3 weeks no problems. Fingers crossed. Thanks justin.......Tim
Good deal!
So is this a confirmed fix?
Justin,
I recently had a similar experience in my 2014 Camaro. It lit the dash up like a Christmas tree one morning. Steering, ABS, Stabilitrak, etc.. Steering went to about half power. Drove it about a mile to a dealer. They kept it two days. They couldn't clear it for a day. New BCM software. Finally, they called and said they cleared it. They couldn't identify the problem. I could see they had been in the trunk at the battery. I think they checked/cleaned the cables. The battery was only a few months old. There are a lot of these experiences posted over on the Camaro5 forum.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
