Question about using the 4WD...
In my '88 Bronco had to back up 10 feet after going from 4 to 2 in order to disengage the hubs and stop the front wheels from turning the front drive shaft.
I don't think you ever had to in a GM at least. When I was in HS I had a buddy with a similar truck as me (both '86 Chevys), but his was 4x4 and even had auto locking hubs and he didn't have to. If you had to in a GM it was back in the 70s or older, but I still doubt it.
The only thing in a GM I can think of where you could back up to engage (not disengage) was a G80 rear end to lock into posi.
The 80s GM products with the D44 or Corp 10-bolt front axles and auto hubs usually needed to at least be stopped or backed up to allow the automatic engagement hubs to disengage.
Manual says to NOT dirve in 4WD on dry pavement or damage may occur...
How is this so?
New to 4WD and trying to learn...
I inadvertently drove our 1500 in 4WD Hi for about 120 miles down Interstate 17 at freeway speeds to home. Didn't realize until I pulled into the driveway and got the tire slip. That was several years ago. No known issues, no noises, used 4WD several times since and worked flawlessly. But I certainly don't say it's OK to do that. Don't know if the NHT package gives you a HD transfer gear box.
But I think we sometimes don't give the Siverado's enough credit for toughness. My 2500HD now has over 198,000 miles, the 1500 is almost 90,000. Except for parts that normally wear out, no major issues with either vehicle. I'm currently shopping for a 2017 1500 with a 6.2, Max Trailering combo. Silverado's for life.
Enjoy your truck.
From the manual for 4X4 auto
Chevrolet Silverado Owner Manual (GMNA-Localizing-U.S./Canada/Mexico-9159338) - 2016 - crc - 7/24/15In Brief 23Automatic Transfer CaseThis transfer case knob is to the leftof the steering column.The different drive options that maybe available are described following.2m(Two-Wheel Drive High) :Thissetting is used for driving in moststreet and highway situations.AUTO (Automatic Four-WheelDrive) :This setting is ideal for usewhen road surface tractionconditions are variable.Do not use AUTO mode to park ona steep grade with poor tractionsuch as ice, snow, mud or gravel. InAUTO mode only the rear wheelswill hold the vehicle from slidingwhen parked. If parking on a steepgrade, use 4mto keep all fourwheels engaged.4m(Four-Wheel Drive High) :Usethis setting when extra traction isneeded, such as on snowy or icyroads or in most off-road situations.N (Neutral) :Shift to this settingonly when towing the vehicle. SeeRecreational Vehicle Towing0441orTrailer Towing0325.4n(Four-Wheel Drive Low) :Thissetting sends maximum power to allfour wheels. Choose 4nwhendriving in deep sand, mud, or snow,and while climbing or descendingsteep hills.SeeFour-Wheel Drive0292.
Chevrolet Silverado Owner Manual (GMNA-Localizing-U.S./Canada/Mexico-9159338) - 2016 - crc - 7/24/15292 Driving and OperatingShift Speeds{WarningIf you skip a gear whendownshifting, you could losecontrol of the vehicle. You couldinjure yourself or others. Do notshift down more than one gear ata time when downshifting.Drive SystemsFour-Wheel DriveIf equipped, four-wheel driveengages the front axle for extratraction. Read the appropriatesection for transfer case operationbefore using.CautionDo not drive on clean, drypavement in 4mand 4n(ifequipped) for an extended periodof time. These conditions maycause premature wear on thevehicle’s powertrain.Driving on clean, dry pavement infour-wheel drive may:.Cause a vibration to be felt inthe steering system..Cause tires to wear faster..Make the transfer case harder toshift, and cause it to run noisier.{WarningShifting the transfer case toN (Neutral) can cause the vehicleto roll even if the transmission isin P (Park). You or someone elsecould be seriously injured. Besure to set the parking brakebefore placing the transfer case inN (Neutral). SeeParking Brake0301.CautionExtended high-speed operation in4nmay damage or shorten thelife of the drivetrain.Engagement noise and bump whenshifting between 4nand 4mor fromN (Neutral), with the engine running,is normal.Shifting into 4nwill turn TractionControl and StabiliTrak®off. SeeTraction Control/Electronic StabilityControl0303.
Enjoy your truck.
We had F250SDs in the Navy. Drove one from Ft Caffee to Coronado with hubs locked. Not a single issue. Went out and bought one and got 230k outta it.
My '82 (1st year w/ the NP208?) had the NP208 & 'automatic' hubs. Shift into 2 Hi & back up 10' & the hubs unlocked.
Before that the General used the NP203 (fulltime 4WD) in AT equipped pickups & K5s. Manual trans' trucks & K5s had NP205 cases & manual locking hubs.
I sure wish they could come up with a hub we could unlock. I bet I could get 15 MPG or better in my 2500. Not to mention the wear and tear on the whole system.
I drove multiple 4x4 GM trucks in the mid-late 1980's. If they had the factory automatic locking hubs, they had to be backed up a few feet to disengage the 4wd. You could even hear them unlock when it happened. When we switched to Warn manual-locking hubs, it wasn't necessary.
Yep! That was my experience too, until we switched to manual locking hubs!
That's correct! You know your older GM's!
Super Duty trucks are tough.....but just because the hubs were locked, doesn't mean that 4wd was engaged. I know lots of guys with manual hubs, and they drive with their hubs engaged all winter, so they don't have to exit the vehicle every time it snows, haha.
There are kits for JK Jeeps. Fairly expensive & from what I understand, not much of a mileage improvement.
Dynatrac...had this on my Dodge 2500. Marked improvement in mileage as they have no axle disconnect and suffered 70mph vibrations from harmonic resonance.
When in 2wd, all that's turning is a couple CV shafts. If the truck is sitting at stock height they provide a lot less resistance than air hitting a solid axle with manual hubs.
Sent from my SM-G920V using Tapatalk
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
