2001 gmc sierra a/c saga
Hello Everyone!
I hope someone can help me with a very perplexing a/c problem. I am the original owner of this vehicle w/ 244K. I try to keep it well maintained. I hardly do any of my own work anymore, but if something needs repair or replace I get it done. Now to my problem.
I drive my truck in the mornings to the Orlando area about 50 miles or so one way. The A/C works perfect on the 1st drive every time. After another stop or 2 down there I usually drive back home to my office. Most of the time now, when I get back in to drive home, after the 2nd or 3rd location, the A/C will blow warm and/or hot almost all the way home. Sometimes it get cold again after 15-20 minutes.
These are the repairs and things I have Had replaced lately:
  • Checked for leaks w/ dye 3x
  • Have replaced High Pressure hose, they said was leaking
  • Have had high and low pressure fittings replaced, they said was leaking
  • I have replaced the 3 dial climate control myself.
  • I even went to a GMC dealer who replaced my air blend door, and it still did that same thing again today after about 50-60 miles and a couple of stops before coming home.
I have an excellent cooling system with no leaks and run 100% coolant.
I am totally frustrated.
DOES ANYONE HAVE ANY SUGGESTIONS! I DON'T WANT TO GET ANOTHER TRUCK, I JUST WANT MY OLD GIRL'S A/C FIXED
THANKS FOR ANY IDEAS
GMC JACK
i dont do any of this work, i rely on mechanics, thanks!
i might be able to by past the low pressure switch myself. how do you do that
i am somewhat handy, just not an a/c guy. im a telephone man LOL
i just checked and i see there is a brand new low pressure switch already hmmmmmmmmmmm.
sounds like a worn compressor clutch. The gap is too wide for the electromagnet to pull it in consistently. Common problem most can actually be reshimmed and work fine for years but the dealerships and most AC shops want to replace the entire compressor. Next time you catch it not cooling get your self a long large screwdriver and smack the chit out of the clutch on the front of the compressor and see if it engages, if so then you can either try to reshim the clutch (takes a special puller tool to pull the clutch) or replace the entire compressor unit, which is probably more practical for most people that do not have the tools or skill set.
Run Run Run! Mechanics just change parts and collect your money. A real technician will diagnose the problem and fix it for much cheaper than a parts changer.
I agree on the clutch check.
when the system is real good, the scavenge line gets ice cold..and wet.
Pump gets sloppy, not tighter...even wets the switches at the pump.
it is an odd opposite of reason to diagnose.
the other weird gadget is the filter at the condenser. It does something with the gas.
if those lose a little chunk, a quick squirt with a screw driver on the high side port will let it out.
it likes to travel. :)
thanks OJ, Barry and Darryl for those excellent suggestions. One of the challenges of this is finding a "real" technician who will "listen" to what my symptoms are.
stay tuned! :)
Had the same issue on my 01 Sierra with nearly 300K miles at that time. Replaced the compressor due to clutch issues.
  • 3 weeks later...
240,000 on my 03, clutch way large gap, being replaced this week. Exact same symptoms, great in the morning, warm after a while and during the day. South Florida
    • I can relate. 3 years ago I did that on my Avalanche. I was sore for a week. The only maintenance I do myself now is drop and fill on the transmission on my Honda’s. It’s just too easy. My yard work with my walks in the morning will be enough now I passed 70. The contributing factor is the heat in Texas. You just have to pace yourself.
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
    • I went from every other day to about once in five since the rain abated. I'm not unhappy about that. Took most of the month for the ditches to dry enough to mow.
