What is going on with my truck????????
Sounds like you bought my old truck. Dealer could never figure it out on mine, eventually I just traded it in. I'm surprised no one has died due to this widespread problem. GM is a bunch of assholes for not doing a recall on this.
Ya because every truck is the same and this is happening on a good portion of trucks, come on man... So neither you nor the dealer could figure it out, how do you know it is the same exact problem then and GM should do a recall? What should that recall be that you and the OP have to fix this? Or is that an ASSumption?
Tyler
Hey Guys just to give you an update took the car to the dealership turned out it was the a bad ground which was causing the resistance. They looked up to see if there was a recall for gmc and there isn't. Going to talk to GMC since I have a case open and see if they can ask least pay half of it. Will keep you guys posted. Total cost to repair this is $430.00
where was the bad ground located? Behind the dash as stated earlier?
It is easy. The hardest part is getting to the ground studs once the dash cover is off. I found out if you remove the tweeters it makes the studs easier to reach (only 2 small screws holding in each tweeter). The whole process took me about 20 minutes.
Popped the dash and checked the grounds, both were ok! Maybe the messages coming up in dash where a fluke, who knows?! The dealership couldn't find any codes.
Did you take the grounds off anyway? Mine didn't have interference with the dash insulation but I pulled them off and they were a little loose. I clean the surface under the nut and around the stud on the dash then reinstalled the nut (tighter this time).
I haven't had any error messages since ...
I didn't. I couldn't fit a socket on there and didn't feel like digging out the wrench set. It's really tight in there (that's what she said)! I'll see if the messages reappear and go from there.
G218 Grounds original poster. 10mm open end wrench can reach them. I did mine last weekend at 67k on my '14. Driver side was pinched. Passenger side was fine.
Were you having any issues yet or just preventative maintenance?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
