Aftermarket foldable bed cover
Looking into a foldable bed cover. Hearing issues about factory spray on liner not allowing good seals where bed meets the cab, allowIng water to get in. If anyone has info on this I'd appreciate it. Looking into the backflip mx2 cover.
No issues with my Undervover Flex and Line-X spray on liner. Keep in mind no folding cover will be 100% watertight. It mostly has to do with how you install the mounting rails.
My TonnoPro Soft Tri-Fold is 99% water tight, and would probably be 100% if I installed the seal on my tailgate that they send, but I don't want to add it. Only leaks on the passenger rear corner. I also have a spray in liner with no problems.
I have a factory spray on bedliner and a bakflip g2 and pretty much no water gets in and it's been monsooning in Florida. Also, the truck is leveled and that hasn't effected the water drainage system on the rails. Only had my bakflip for a few months but it works and looks great.
The joint between the tailgate and bed sides is not 100% waterproof, so no matter what cover you use, a little water can get in. But generally even that stays dry.
I have the Extang Signature tri-fold and did install the tailgate seal. Any rain/weather event leaves entire bed cavity 100% dry. When I go through the carwash I use, some water gets in but only at the absolute rear near the tailgate. That's likely from the sideways pressure spray, possibly impacted somewhat by the rolling brush.
We don't experience that phenomenon in nature, or if we did, getting your suitcase wet would be WAAAY down your priority list.
Funny - I have exactly what Silverado Steve posted above..... 2017 Denali crew cab - Did not come with factory spray in. I went with LINE-X (It was a little more expensive then the other aftermarket spray in) to be honest I use my truck "as a truck" less than 20% of the time so it was probably a bit overkill. I was told it was the best so that is why I went with hit. I also have the Undercover FLEX trip-fold top. Very nice top that I have had no issues with. Just remember to pop out the drainage holes and place the flex tubes from the cover in them. - I also agree with the statement that non of the fold tops will be 100 waterproof.
I bought a Tyger tri-fold tonneau cover for $215 off of Amazon and I love it. Looks sharp, are it keeps the bed dry. Just as good as the $800+ covers the dealer sells
+1 for the Undercover Flex. Have had one on with the factory spray-in liner for about 6 months. No issues thus far. As others have said, not 100% watertight where the tailgate meets the rest of the body. But water intrusion is minimal. Drove through a heavy thunderstorm on the way to Florida last month with all of our luggage in the bed. Completely dry when we arrived.
Bakflip mx4 is absolutly waterproof on my spray bed liner. Only place alittle water gets in is between the cracks of the tailgate on the sides which has nothing to do with the cover.Usually only happens when I am washing the truck
I got mine for $705 delivered which is the cheapest I have seen anywhere
    C. Hart
    C. Hart
  • Who's Online   3 Members, 0 Anonymous, 518 Guests (See full list)
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
