Hub Centric Wheel Adapter Questions
Irby1757
I know that there are a few old conversations about this, but wanted to see if I could get a few opinions from everyone. Just added a Zone 6.5" lift with a +18 offset rim. Before putting the lift on a lot of my research on here showed that a good amount of people were running a wheel adapter. I decided that I would just get the lift on and probably be able to live with the difference in the front and rear wheels, well i can't stop looking at it. I called my local truck shop, and they gave me a good price to install some 2" spacers this weekend. My concern is, I have not seen this brand talked about on this forum, or others. The shop says that it is the only brand that they recommend though. They are West Coast Spacers. Anyone with experience with adapters, or input on these would be very welcomed.
http://www.westcoastacc.com/product/billet-adapters-width-application-diameter/
I have 0 experience with any adapters but I'm looking at adding some once I get my fender flares to the tires align with the flares. Just out of curiosity, why not just install them on your own? I assume this is one of those "if you can change a tire you can add these" sort of thing.
I wouldn't recommend any spacers that are not hub centric and not made by Bora
Sent from my HTC 10 using Tapatalk
I have used 2" spacers several times. Before using them, I researched it. Here is what I found:
Make sure all mating surfaces are very clean.
Don't ever buy used spacers. Only use brand new ones.
Hub centric is the best option. Try to find that. If you cant, you can use hub centric rings, but they are not as good.
Install them with the EXACT torque that the manufacturer of the spacers recommends. Re-check all the bolts for proper torque.
Drive them for 10 miles or so, and then re-torque the spacers. 10 more miles, and re-torque them.
Remove the spacers, and re-assemble everything with medium strength ThreadLocker.
Torque to the same spec. Quickly Drive for 10 miles before the Threadlocker dries, and re-check the torque.
After that, don't check the torque again, or you will mess up the ThreadLocker.
Misc:
Spacers are weird. The aluminum spacers slightly "compress" when installed. Over torquing them will destroy the spacer and cause the bolts to come loose while your driving. They can be dangerous if not installed correctly. In some areas, they are illegal.
If a repair shop only recommends one particular brand, here is why:
Its the only brand they sell OR its the cheapest spacer they can find wholesale.
Installing on your own isn't out of the question, but for what they are charging and my truck going to be there anyways for a recheck on the alignment makes sense to just have them install them.
Hub centric is a must, but many companies make them now. I know that Bora is the top discussed spacer on this site, but have others used another company that has failed?
I recently went ot the dealership to get an idea of the difference between lifts and saw that they had installed spacers on their lifted vehicles. I also know they weren't Bora due to the color of them. Of course, the agent that walked outside to talk to me had no clue.
this! And 1.5" is the ticket.
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 AF Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
