Fuel
Mervkirwin
I just purchased a 2017 GMC Sierra SLT All Terrain with the 6.2 L , I see in the manual it states to use 93 Octane in the truck for better fuel mileage and performance. Does anyone know if this is true and have you noticed better gas mileage.
GM will always suggest to use top tier fuels no matter what. In my 5.3 I've only ever run 87-89 and it runs fine. MPG average on the DIC shows 29.1
If I remember right, I have read where some 6.2 owners accidentally put in regular 87 or equivalent and the engine didn't seem to run right. The 6.2 is tuned to run on premium so that's what you should run. Sure it will run on a lower octane if you're in a pinch, but I wouldn't recommend it and just stick with premium. I also never use any mom and pop store to fill up. Always a top tier brand or just well a known brand.
As you already know: The octane scale is the opposite of what most people think. The higher the octane, the lower the combustibility. So low octane fuels can produce more power (theoretically). Why do we put high octane fuel in race cars and high performance engines? High performance engines need to have less volatile fuel to keep the engine from exploding. Some of the fastest cars on earth run on alcohol, which is obviously less explosive than gasoline. Running too low of octane could be looked at like this: Your running a fuel that is too powerful for your engine. The volatile fuel will detonate too early, and cause random explosions inside your engine. Your engine tries to compensate for the unplanned explosions by retarding the timing. You want your engine to run in its ideal environment, so that it will be efficient and last as long as it can. Save pennies at the pump to destroy your engine. If you really want to use cheap gas, just "cut" it with something to lower the octane. When we raced bikes competitively, all the well known national guys ran a mix of pump fuel and airplane fuel. The airplane fuel was very high octane. What ever your rig calls for, use that.
High octane top tier fuel is cheap insurance to keep your motor happy. The timing is adjusted on the fly by the engines computer and higher octane allows for more timing advance. Timing advance adds power and efficiency, but only up to the point where the engine can tolerate it.
If I had a 6.2, I wouldn't run anything less then 91 octane. With my ScanGauge monitoring timing and KR (knock retard), I have witnessed first had the affects of lower octane on my 5.3. I try use at least 89 and will occasionally use 91 if the price is right. Since the 6.2 has a higher compression (11.5:1 vs 11:1) using anything less then 91 will most likely result in KR and timing be retarded (aka loss of power).
29.1......i haven't seen that good on my yet. You must be keeping it below 30mph all the time.... :lurk:
Maybe he's using km.
Mostly agree. However, it was recently pointed out to me that all the gasoline has the same specific energy (BTU, joules, etc). The "octane" ratings are now controlled with primarily anti-knock additives. A reference was cited and I did read a article supporting that. But there was a time that high octane was lower specific energy fuel
I have also ran into this because in my spare time I like to fix up old 2 stroke street bikes. Back in the 60's and early 70's these bikes ran on regular pump gas but the octane reading back then is much higher in reality than what it is today. To counter this I mix non-ethanol 93 with 100 octane racing fuel (the racing fuel has ethanol so I don't like to run it straight). On my more modern motorcycle (large air cooled V-Twin) I run the lowest octane gas I can get away with (bike requires 91 or higher octane) which means 87 in the winter, 89 in the spring and fall, and 93 in the heat of summer.
Black Bear Performance informed me to run at least 89 in our 5.3 even if it wasn't tuned. They said these new engines benefit from higher octane and running anything lower isn't recommended by them from what they are seeing when tuning the 5.3 and 6.2.
I have a 5.3, and live in Mexico, we only have 87 and 91.
I wouldn't dare putting Mexican 87 on my truck,
I hate the fact that I can only have Pemex fuel. Damn Socialism :(
All hail free market
Octane usage is based on compression ratios and timing curves. 5.3 liter can use 87 octane because of it's compression ratio of 9.5 to 1, whereas a 6.2 liter (L86) runs 11.5 to 1 compression ratio. That is why the manufacturer recommends higher octane fuel.
Another little factoid, the 10% ethanol blends are great for cold winter start ups but recommended in very hot Arizona weather.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,180 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
