Bye Guys/Traded in the Silverado
I forgot about the rotary shift knob.. yeah, that was a tough one but ego aside I guess you'd get used to it. Couldn't help but think that it belongs in a Prius, not a truck though. Not a fan of the console mounted shifter in the Fords either, it's a waste of console room.
  • Replies 31
Not knocking your truck bro, they all have theirr pluses and minuses. Ram makes a really nice package and I could have overlooked it's minor deficiencies if I weren't too tall for it. No truck is perfect, GM certainly isn't, it just fits me great. Different strokes for different folks.
Ford was immediately ruled out because I cannot wrap my head around spending $50k on a new truck with a ****ing V6 in it, I don't care if it has 10 turbos. I like their trucks but the 5.0 is weak as their only choice of V8.
That's true, and it's funny becasue I really like the Dodge/GM V6 entry level engines alot, better than the Ford packages. I would love for a gas straight 6 to become an option again.
I will say the RAM Laramie I test drove had one hell of a nine speaker Alpine audio system. Rotary shifter didn't bother me much. I also liked how when you folded up the back seats, you could fold out a raised flat platform. Perfect for my dog. The running boards extended back to bed in to just in front of the rear wheel well which was nice. It did shake on the test drive which is primarily why I walked. If it hadn't been for that, I'd probably be driving a Laramie today.
Best of luck with your RAM. They make a really nice truck, I'd probably buy one if payload wasn't an issue. The Hemi is a strong motor and they seem to know how to tune a transmission.
Definitely ride smoother. My uncles Longhorn is much smoother than my 16 Denali. They have coil springs in the rear. Less payload like mentioned. Also can get better deals on the Rams. It is dated now.
GM, Ford and RAM have their own drawing cards. The one feature of RAM that could eventually win me over is they are the only one of the three that offer a manual on one of their full size trucks. The big draw for me in a Sierra/Silverado is the looks and the big, non-turbo 6 cyl. If they allowed the manual transmission offered in GM trucks outside of US and Canada,there would be a new GM in my driveway!
The RAM is an older platform, and the safety ratings are not up there with the new F150 or GM. I know a lot of guys in my business that have RAMS. Even an Eco-diesel with 70k. They ride awesome, the 5.7 is a beast. When people say the payload is low, by how much? I compared a CC/SB 5.7L 4wd against my truck and IIRC it was about 200 Lbs lower than mine. not really a HUGE amount lower like everyone rags on. The rebel and specialty builds have much lower payloads, but the Long horn or Laramie vs my truck.... within 200lbs. one thing that has driven me nuts about the RAMs is the on the passenger side foot well, it's cramped. Why is the footwell area upfront so small?? It's like a 80's conversion van on the front pass side. And the 5.7L has 16 spark plugs and burns 89 octane with no direct injection. Not very business budget friendly. That's what kicked me over to the GM after test driving a Laramie. But I can see why people like them, nice riding truck with a lot of power and a good trans and big 20" rims. It's a great driving truck.
Going back to that RAM coil rear suspension.. I don't know about you, but the rear stabilizer bar on them hangs down and looks ugly, and is the diameter of a pencil. Also, there are a lot more moving parts. I realize that a few guys have noises from the infinitely simpler GM leafs, but for a truck, they work, and have for generations.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
    • Not what I said but I can work with it anyway. Complete combustion produces CO2 and H20. When it's cold enough you can 'see' it as water vapor but it is always there and more so the better the tune up. It's physics, not an argument. In a cold motor when the cylinder jacket is below the condensation temperature the water goes to the pan and not the PCV system. Heating the oil moves it from liquid to vapor where it is removed by the PCV system. When and how much depends on temperatures. Of the air, the water and so on. It has little to with the humidity. Water is a combustion product.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
