New member from Mahoning Township PA.
John1493
Hello to everyone, I have been reading the site a long, long time thought I would finally join and hopefully become a productive member of your already very well informative forum.
A little background on myself, I've owned gm trucks or a gm product since 92. First one being a 73 Blazer with 38 inch Gumbo mudders. Now my daily is 2014 Silverado LT Crew and my toy is a 93 Silverado regular cab with 9 inches of lift and 38's.
Thanks for reading, John
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
