Looking at swapping out my bumper on my 2017 silverado and of course have some questions.  Reason for wanting to swap out is be able to mount some DOT foglights.  I've only looked at OEM bumpers but would consider aftermarket if its similar priced and some DOT fog lights can be mounted.  I'm aware that getting the foglights installed to work like factory is quite the undertaking but I'm not concerned about that and really am just wondering how much compatibility there is between the different trims/years of bumpers.  Seems the bumper off the midnight edition truck is what I'm looking for.
Seems there is only a few basic bumper for the 17 siverados.
WT
Body colored w/o fogs
Body colored w/ fogs
Chrome w/ fogs
I'm assuming the bumpers are modular(hopefully someone can clarify) as I've seen the above configurations with different color lower valences but just from pictures online its hard to tell exactly how many different variations there are.   Silver & flat black for sure and possibly chrome and body colored?
Are all the bumpers interchangeable? How many parts make up the bumper? Are they available from the factory painted?  What parts are reusable from my current truck?  Can the earlier 14+ bumpers be used? Are all the bumpers metal like the WT bumper or are they polyurethane? I'm assuming the tow hooks are all the same.
Are all the 16+ foglights LED?  Whats the part number?  Do they come with the mounts or mount to the bumper directly?  What bulb connector do they use?
Heres some pictures of the different bumpers I've found to save people from googling...
WT (WT, Special Ops, Blackout Edition)
ca-2018-chevrolet-silverado-1500-pickup-
Body Colored W/fogs, Chrome lower valence??? (z71?)
Body Colored w/o fogs, Blk lower valence (rally 1)
Body Colored w/ fogs, Silver valence (rally 2)
Body Colored w/ fogs Blk lower valence (midnight edition)
Chrome w/ fogs
mm_gal_item_c2_1be7.img_resize.img_stage
Post up a picture of your truck you have now (large size picture) and I can photoshop the different
bumpers on it to help your decision.
WT
Chrome w/ fogs
You can add 'Chrome w/o fogs' to your list. I have this on my 17 silverado crew cab LS.
  • 10 months later...
I’m researching replacing a 2500HD front bumper with something similar to the 1500 bumper in the above roger Beasley photo.. Are they interchangeable? I have found no minimalistic bumpers for 2500’s.
If you want to go OEM, I have the black WT bumper, and I will also have the chrome with fog lights bumper available shortly.
6 hours ago, etanate said:
This may be a dumb question but Do the 1500 bumpers fit on the 2500?
No.
Seriously thinking of a PIAA light mount #30765 and one or two pairs of PIAA 520 series lamps on it.   The factory "fog" lamps on my 2018 are nothing more than accent lighting.
  • 2 years later...
4 hours ago, GavinRowbotham said:
I have a 2016 Sierra 1500 which other year front bumpers will work with it?
16 - 18, then it depends on options, park sensors, fog lights, painted....
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
