On 11/4/2017 at 10:39 PM, HoosierZ said:
Yesterday, I installed a Reese Compact IQ controller in my truck. The controller is mounted behind the dash near the parking brake pedal and I mounted the adjuster dial and indicator LED in a panel over the pocket above the 4wd selector dial.
Would you mind posting a pic of where you mounted the controller?
It’s mounted to the metal support above the parking brake pedal using the double sided foam tape that came with the controller. The wires to the LED and dial were barely long enough to reach up to the pocket. The wires are ran along the bottom of the dash and across the fuse panel. I’ve since molded in a panel over the pocket.
I had the Redarc in my Silverado 1500 LT.  Worked great with my trailer and install wasn't too bad.  I put it under the screen where the heated seats button would be in the higher trim trucks.
Traded off the 1500 for a 2500 HD and didnt grab any picks of the install.
Edited by mammut
On 6/19/2018 at 9:09 PM, HoosierZ said:
Wire loom hides the wires hanging below the dash.
Thank you for the Pics!  being that it has to be mounted in a very specific way i was struggling to find a location.
Got my compact iq installed.
Did my install a few weekends ago. I mounted my box on the metal bracket below the steering wheel, behind the lower panel.  I didn’t take a pic of it though.
ce7HMMStNgjkzKaucM96xdej0ohnGVPa6UhOJDEV
This is the only thing visible on mine (systems status via backlit led)....control box is hidden up under the dash.
  • 11 months later...
Looking to add a controller and leaning toward P3. Anyone tried to mount in center console under the removable cup holders vertically? For trucks with captains seats with fixed center console. From what I read vertical is okay. Not sure if wiring long enough though.
Where did you get the plate to cover the hole? Is it something I can buy somewhere or did you make it?
  • 8 months later...
Where did you get the panel?  My 2016 has a cubby...
I made the panel. It had angle brackets behind it that were attached inside the cubby with emblem tape and the panel was attached to the brackets with velcro.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
    • It is 4wd. shop told me it is the slip yoke. But not sure.
    • No, I did not tune out vvt. From what I read it should still be able to run without it, it'll just lose some torque/power.    I can see how that would make it not run correctly, but why would that cause the faulty MAF readings?   EDIT: I just ran a quick test and checked, and as I expected, the computer sees that the VVT cam phaser solenoid is not present, and throws a code for it, and does not try to change the cam angle at all. Commanded position just remains at zero, 100% of the time. This makes me think that the VVT is most likely not the cause of the problem though if anyone has a different/better explanation, I'm all ears.   UPDATE: I was able to find that my scan tool does indeed support reading the frequency (hz) off of the MAF (I thought it wasn't supported but turns out I just didn't know where to look for it). I noticed that regardless of engine state it always however this Is not what I observed with my multimeter. Like I said before, the MAF seems to put out a normal signal during cranking and then the signal drops to a very erratic reading once the engine is running. It seems from what my scan tool is telling me that the ECM is not recognizing this at all, and just reads 0 Hz 100% of the time. This pushes me towards the the PCM itself is faulty. I I have the PCM out of the 2007 donor vehicle, which I may try to connect and program (it's only ~50 bucks to get the software for a one-time programming)
    • Did you tune out the VVT?  07-09 they did not have VVT.  2010-2013 they did.      If you haven't tuned it, its trying to adjust cam timing.
