I have a 2017 Silveraro LT. It has 23, 000 miles now and the last few times I filled up the gauge didn't go to the full mark. I just goes a little past 3/4. I just filled up and drove about 60 miles and the gauge is at 1/2 tank so I stopped and filled it up again and it only took 4 gallon to fill it up.
Anyone else having this issue?
oh no.  Hopefully we are not going to see another profound issue with faulty fuel sending units like we did on the GMT-800s.
My 17 All Terrain has done the exact same thing a few times. Only difference is that it stuck at about 3/4 (while still at the pump) for a while and only after I drove a good distance did it continue going up. I know it was full because the pump indicated 21.5 gallons from being on E.
If it does it again I'll be taking the truck in for service. Starting to see some issues with it. Its a shame I've only had the truck a month.
  • 2 years later...
I have a 2018 Chevy Silverado LT. I fill it up and the gauge works fine. Once it gets down to a quarter of a tank it stops reading correctly. My wife has ran out of gas 2 times on the side of the interstate so now she wants to get rid of it. Does anyone know of a fix for this problem?
Kirk, did you get the problem resolved/diagnosed?  I have the exact same symptoms on my 2017 Sierra with 56K miles.  I am assuming it is the sending unit.
Folks- Kirk only made one post back in 2017 and hasn't been back since.  Don't expect a reply.
Hello, just wondering if anyone has an update on this problem.  I have a 2017 Silverado that only reads 3/4 full when I fill it up then it slowly moves to full. It does this intermittently and sometimes does not go to full tank. Thanks for any updates.  I will be taking it to the dealer soon.
Took it in for service and confirmed the fuel level sensor needs to be replace. They ordered a sending unit, which I will have to take back to service to replace once it arrives due to this part being on back order.  No actual time frame. I suggest to take your trucks in most likely same response is what you will get unless they have the part in stock.
    • How did all that extra get added? AI bot!
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
