Brake fluid Change?
On 1/7/2018 at 3:16 PM, davester said:
The motive power bleeder is NOT "universal".  If you go to their website, they list a number of different caps, based on make/year, because everyone doesn't use the same cap, and it has to fit very well or else you wind up just spraying brake fluid everywhere.
As a second note, if you use it, and try to follow the instructions in GM's full-service manual for pressure bleeding, the pressure that GM says to use can/will blow off the plastic cap they normally sell for GM's.  They make a billet-metal one that will stay on when under that pressure for a little more money...
Actually that cap that comes on the listing I posted IS universal. True it may not fit every single mastercylinder known to man, it's fit my silverado, mustang, vw, and kia.  If you have many vehicles, like me, it's more cost effective to buy the universal cap and not the vehicle specific ones.  To each their own, I realize everyone is an expert on the internet.
Also you only need about 15 psi to bleed the silverado brakes. It may bleed slightly slower but we're only talking a minute extra in time.  If you can blow off the universal cap it's because you didn't connect it right or you pressurized it to 5000psi (which isn't possible).
I'd be more than happy to post up some pictures or a video if anyone thinks the universal cap won't work with the silverado.
Back in the day, we never replaced the brake fluid. I had a 1957 Chevy that I owned from 1978 to 2000, never fluched it once, or replaced wheel bearings, come to think of it I replaced the wipers maybe once.
Sent from my SM-T817V using Tapatalk
I built a pressure bleeder using my pump-up garden sprayer and a replacement master cylinder reservoir cap with a barbed hose fitting to attach the sprayer hose to. I was able to flush the fluid in my ‘08 Silverado in about 30 min. The sprayer has a valve stem added to it to pressurize it and check the pressure with a gauge. 10 psi worked great.
I did this exact same thing with my 2010, worked like a charm.  (I installed a pressure gauge directly to the sprayer bottle)
At 40k miles, the fluid was dark as coffee.
I noticed tonight actually, the fluid in the reservoir of my 2015 was starting to darken.  (28k miles)  I'll probably flush it come spring around 35k, a little over two years of ownership.
I built a similar one years ago also. Mine has a pressure gauge on the side of the spray bottle. I used it for brakes on my old corvette. I have since used it to pressurized the coolant system on two vehicles to find a leaky water pump gasket on my own 02 Z06 and a cracked radiator in my wife's H3. Handy tools.
    • Yes I agree, its what amounts to free advertising to let people know about his UOA testing company, and not that there is anything wrong with that but certainly that is a motivator for putting out videos about the science of oil as well as other topics such as oil and air filtration etc. The interesting part I found with his last video is not only the physics behind the reason for the varying wear due to a diesels working torque range causing more bearing load and that higher viscosity oil is of benefit, it was also that the chemistry behind the GM Dexos 0W-20 and the Mobil Dexos licensed 0W-20 are far enough apart that its showing up with a difference in wear even though the two oils are matched in viscosity and in that comparison viscosity was not having the finger pointed at it.    Thankfully youtube is free ( yet anyway ) for viewers to sift through information and of course comes with the good and the bad ( truth and lies ) and we can choose to turn off/not watch what a person finds is bs or just not interested in the topic.
    • No doubt... But, as someone who doesn't pay for his services, but who has provided a few views/clicks on his Youtube platform, the data around the Mobil oil testing I think does have some value including to "freeloaders" like me.   A lot of what he's doing is likely showing the OE's work in their oil selection, something that many of us had kind of assumed was true all along, a good balance of both excellent protection and efficiency.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
    • I agree with this assessment. As you know I’m testing longevity with vehicles for the first time. I have a few vehicles I passed to kids and grandkids. We’re all past 100K miles some approaching 170K. I’m the only one doing 5k oil changes. The rest whatever the minder says. I’m the only one doing frequent transmission service. My odyssey the trip vehicle at 200K will be finished as a trip vehicle. I recently changed to high mileage oil, Valvoline. I can’t get past the fact that all manufacturers want to claim long service life. I just don’t make sense that they would go with low weight oil for mileage. While sacrificing longevity.
