GMC-AT Posted January 9, 2018 Posted January 9, 2018 All bulbs are working lighting up fine, both blinkers are working fine....it's just one side blinks real fast . Any ideas?
GMC-AT Posted January 10, 2018 Author Posted January 10, 2018 plan old stock bulbs. Even though they appear to be good, thinking about changing them to see if fixes..
O_J_Simpson Posted January 10, 2018 Posted January 10, 2018 A bulb is bad on that side. Swap them all out.
insidethreat07 Posted January 10, 2018 Posted January 10, 2018 A bulb is bad somewhere. I used LEDs and a different flasher for mine
muddkatt Posted January 10, 2018 Posted January 10, 2018 Then you have a bad bulb or socket on that side.
GMC-AT Posted January 10, 2018 Author Posted January 10, 2018 I'll replace the bulb and blinker fluid later today and report back.
GMC-AT Posted January 10, 2018 Author Posted January 10, 2018 ok.. changed out the rear bulb, no help. Noticed the front parking lights wasn't blinking - however, the light was working on the parking light function, but wouldn't blink when I turned on the blinker. Anyway, I changed the bulb, no help. After that I pulled the bulb back out and put back in reversed.. fixed! The issues was either 1. The bulb was in the wrong way ( didn't know these bulbs have reverse polarity? ) 2. I noticed a some corrosion inside of the bulb socket. Maybe when I removed and reversed it got a better connection ? Either way.. it's good now.
