bug/stone deflector
iron_786
I like that Cupton, I was going to do one like that, struggled with which way to go. I kinda wanted to match the bumper.
I use the Meguire's Natural Shine wipes, drops a coat on it, can't even tell, and stuff wipes right off, bugs and all.
Just got my BedRug, and RetraxPro MX cover installed Tuesday. Think I'm going to spray the clamps matte black....
I was thinking of color matching too but couldn’t find it in my color. That’s how I ended up with the black. I was torn between the smooth vs. textured so I settled on textured. I actually really like the black now. My truck has a fancy man mustache.
i just got the AVS too.  Low profile, and looks good. Only been on a day so can't say how it performs but so far so good.
That is what I have been looking for.  Do you have apart number?
Sorry for the delay.  Hunting season has started up here in the great North and cell is spotty at the camp!  The dealer didn't put the part number on my receipt but it does say "bugflector" and I know it's the lower profile one so I think  25131 is the part number for my 2018 Sierra 1500
I put a Weathertech hood deflector on my ME.  I like it a lot aside from the extremely crappy installation hardware they used.  I preferred the way this one installs vs others that require you to install those tabs over 3M protective tape on the lip of your hood.
Another vote for the AVS Bugflector II.  I've had it on my 2015 since 2016, and no issues with the tape.  It's held on no matter what I've put it through.
So does anyone have the matte-finish Aeroskin II version with the extra lip on the top?
I see member CUPTON has a similar one that doesn't have the lip, which I might go with.....
