Questions for Catch Can users
bkesting
  • Replies 44
28 minutes ago, Austin66 said:
1.  I like the one I have: ebay ADD W1 replica for $40.  Pulled 2-3oz out already in less than 500 miles.
2.  I made a bracket from metal stock to mount on the brake booster bolt.  I have no problems with dipstick access.
3.  NAPA/Carquest transmission line is more than adequate.  I went to my local hose shop (you probably have one too) and got some gray cloth braided line for about the same cost ($4/ft).  Their trans line was $2/ft but the line I got looked and felt killer.  I had to have it.  Basically, check your local hose shop first.
4.   Since I put on a CAI, I was curious about the 'clean side' tubes reverting oil back into the intake tract.  I've checked the inside of the tubing several times, including after several 0-80 WOT blasts in succession.  I also tow regularly.  Not a smidgen of oil in the tubing or on throttle body.  Because of that, I believe the clean side separator is not necessary (for me anyway).
Good info. Thanks!
I just bought the dual outlet E2-X and two check valves from Elite Engineering. I'm going to be putting this on a 2017 Sierra SLT Crew Cab 6.2L with a Magnuson TVS1900 Supercharger and a Black Bear Tune. I might end up doing water/methanol injection or straight methanol injection later on down the road.
I have to say, Steve at Elite Engineering was a pleasure to work with, and he was VERY responsive via email. I was getting replies to my email questions in under two minutes today! Thanks Elite!
Can't wait to receive the product so I can install it ASAP. I should have purchased this immediately after buying my truck, but I only have 4,100 miles on it, so it's probably fine. But for everyone else out there, don't wait because there is truly no point in waiting. It's a necessary mod whether you'll be stock or will be doing engine upgrades...and it's something that can be removed and used on a different vehicle later on.
He was great with me too.....very fast and responsive. I have 15,000 on mine (bought used) but hope to still get great benefit from this
On January 30, 2018 at 5:29 PM, DPetry94 said:
I've got the hissing noise with the hose they provided too, and a little bit of ovaling in the house when the truck is running. Didn't you ever replace yours?
Sent from my XT1650 using Tapatalk
It hasn't annoyed me enough yet but you know what they call tax return checks? Car parts lol.
Lol so true. Thinking I'm gonna get a new toolbox though!
I actually just picked up some transmission line the other day, gonna install it tomorrow and see if it helps.
Yet when i called they wouldn't give me an upgraded hose due to the hissing noise...
Nice. I was going to pick up some 350PSI line but haven't gotten the chance yet. Its also a pain the rear to re-install the lines.
I literally emailed them and they acted like what I was saying was the craziest thing they've ever heard. And since then I've emailed twice and haven't received a response...
Yeah same thing i got. Maybe if they read the forums more they'd realize that the hose they provide is insufficient.
That was the issue with my 2017 truck too, AND with my previous 2013. The basic rubber hose supplied by Elite is a joke. It will collapse  and hiss with the vacuum experienced in those lines. Love the can, hate their hoses.
    RyGuy43
    RyGuy43
  • Who's Online   1 Member, 0 Anonymous, 369 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
