This truck is my job....if it doesn’t work neither do I......This morning the dealer told me it would be next week before they could get to it! No thanks, I’ll regen it myself! They said that there’s another identical truck doing the same thing and they’ve already thrown 3 DPFs in it. The customer picks up the truck, tows a 10,000 lb load up I-70 through the Eisenhower Tunnel and the truck goes into limp mode! Customer drops the truck back off and picks it up a week later. &repeat &repeat&......Apparently an engineer from GM is trying to figure it out? What a colossal waste of my time and money.
  • 7 months later...
I have a customer using a 2017 silverado 3500ltz for hot shot hauling pulling a 40 ft gooseneck. now has 217k miles and on the 3rd set of headgaskets, 1 new head,4 exhaust valves, and an egr cooler with all the plumbing. this truck WILL NOT regen while driving. Has to be mznually regened every weekend.dealers have no clue except to charge him $300 a crack to regen when the warr. ran out.GM has no clue why this truck won't regen while driving. Has had the ecm reflashed7 times with two replacements due to internet errors that locked up the laptop and ecm.There is no aftermarket on any gaskets for this POS. Have to go to the dealer for all of it.I'm in northern ohio about to leave for southern kentucky to manually regen this truck along the road. has an extended warr.purchased at the dealer thats only good at that dealer.This truck is going to be traded in on a Ford asap!!!!!
  • 2 months later...
63,000 lost injector 7, 72,000 miles lost injector 5, replaced connectors on both, had no idea of the ECM issues.  Right now my trick is down with low voltage going to half the injectors, some one please tell me a re program of the ECM will fix me replacing injectors again.  Do I need to order a whole new ECM?
  • 1 month later...
  • 7 months later...
My experience has been somewhat of a nightmare.  Mostly on the quality side.  I bought it in July of 2019 with 9600 miles and now it has 32000 miles.  I havent had many problems with the engine itself but the jury is still out.  Below is a list of parts that have been replaced on my 2017 2500HD LTZ and the symptoms.
Power steering pump - making grinding noise while turning normal (i.e. it still makes noise when locked left or right, pretty normal for all pumps).  Took the dealer two visits and me driving with the tech to diagnose.
Fan clutch - AC would not work when outside temp over 100 DEGF, no engine overheating.  Took the dealer 3 visits to figure it out and of course it was out of warranty when they found the problem.
Water pump - After having the engine block heater recall done I would get the low coolant notification about once a week.  Top it off and a week later it would come back.  Dealer said they saw the weep hole dripping under pressure.
                         They replaced the water pump and a week later the low coolant notification is back.  Probably a bubble in the system somewhere but they cant get the fill procedure correct I guess.
All front diff bearings replaced - When 4H was engaged there was a loud whirring noise.  Dealer replaced all the front diff bearings.  On the test drive after replacing they heard something in the transfer case.
Transfer case chain, drive and driven gears replaced - After replacing the diff bearings they heard something in the transfer case.  They opened it up and found the chain was loose.  They replaced the chain and gears.
Oil pan replaced - oil was weeping from the front of the pan.  After the third visit they found the leak.  They replaced the oil pan and resealed
Drivers side mirror replaced - The chrome cover and body were not matching up leaving a large gap.
Plastic strips between the cab and the bed peeling off - the first dealer wouldnt replace despite being in warranty.  The second dealer replaced and 5 months later they were pealing again.  I finally asked the dealer to just remove them.
The only thing I have had to pay for is the fan clutch which i only paid 40%.  I have been fighting with GM corporate for 6 months now about the quality of the truck and the fact that in the last year and a quarter they truck has been in the shop a total of 70 days.  This doesnt include the low coolant notification coming on three days ago.  That will add another 3-7 days most likely.  It blows my mind that GM cannot recognize that a power steering pump or a fan clutch, for example, should last longer than 25K.  They keep saying "sir, it was fixed under warranty" or "you only paid 40% of the cost", like they did me a favor.  The truth is those components should last at the very least 80K.  I realize it is all about money, I get it, but when you pay $60K for a truck that is touted as "heavy duty" you should expect those components to last quite a bit longer.
This is just my experience and reading about everyone's positive experiences gives me hope that things will start looking up for my 2500.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
