5.3 1500 vrs 6.0 2500
10 hours ago, 426power said:
OK guys I test drove a 2017 2500 HD 6.0 and all I can say is it's a dog stock. With the heavier truck my tuned 5.3 has a lot more power. I understand about the suspension and the rear end on the 2500, but at this point the 1500 is going to be tasked with pulling the trailer until I have had enough and bite the bullet for a Duramax.
5.3 is a dog stock as well
  • Replies 40
A couple people highly modified their 5.3 to run 13s in the 1/4 mile. You need extensive training to do it, they added E85.
Good decision.  Your experience with the 2500 was unfortunate but don't rule them out.  Running like a "dog" is an expression that shouldn't apply to a properly running new GM truck.  They all come from the factory designed to handle all normal driving scenarios.  When you decide to use your truck for heavy loads or to race RAMS is when you notice the difference.  Take a newer 2500 for a test drive with your trailer attached and you will feel the difference.
You don’t need it highly modified to run 13’s.
there’s a guy on here named gorske, runs 13’s on e85, a tune, and a converter, and it’s not a regular cab.
That was the point. Sarcastically replying to the previous post that the 5.3 was a dog.
Well it a dog stock, he’s going from a tuned 5.3 to a stock 6.0. Infact when I had a 5.3 loaner, coming out of my stock 6.2, the 5.3 felt like it was down 200hp.
hell a stock 6.2 wouldn’t feel any faster than a tuned 5.3. The torque management and throttle response makes all these trucks “feel” slow when they’re stock.
It’s a shame you’re so hard to please. My stock 5.3 was faster than most of the performance vehicles I owned in the 70s-90s. I could feel it. It was probably the slowest of my vehicles at the time, the sensation of speed was still there. Definitely not slow.
2 hours ago, j-ten-ner said:
Sometimes I wonder what some peoples dogs are like...
so long
j-ten-ner
Old dogs can be slow but most healthy dogs born after 2014 are really fast!
You’ve owned some incredibly slow vehicles than.
If you ever get to conroe tx pm me I’ll show you slow. And bring diapers.
 Lol, I’ll never be in conroe texas, ever
Horse power is not a problem. The advantage with the 2500 is the heavier frame and axles. But it makes them quite a bit heavier than the 1500. Which is the main reason it feels like a "Dog".
I wouldn't have a problem towing with your setup.
Wew going to get a lot of responses with this question but I have both of those trucks in our family 5.3 & 6.0. I would pull your load with a 2500HD first before the 5.3 simply just braking, control and I could relax a bit driving because the 2500 is a larger platform period. Forget the 5.3 tune doesn't mean anything in real world pulling its about stopping, control of the trailer and some safety factor of sorts using a larger truck. Is it doable with the 5.3 sure but since you asked for which would be better 2500HD.
Spot on Don, there is a lot more to towing  a trailer than just how quick the tow vehicle is, don't think I've ever seen a drag race with a p/u towing a trailer, or for that matter racing up Pike's Peak. Now that I think about it, a 1500 6.2 might win the 1/4 mile towing a TT, but the 6.0 2500 would make it to the top of Pikes Peak either before or after said TT pulled the 1500 over one of those embankments, long ways down.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • 2024 Silverado 2500 HD LTZ grille no camera Parts list   84603331 84913656 84913657 84913654 84913655 84911567 84911568 85646092 85646093 85797921 85797922   11570637  x10-15   grille/bumper bolts 11546500  x10      grille clips 11571006  x10      push/retainer clips 11546454  x6       nut retainers 11611609  x6       M5 bolts 11610700  x6       molding/trim retainers
    • And use RA's 5% discount code if you buy from them.  google for the code, one is always available.
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
