So my problem is just what the title says. My 2 year old "princess" decided to drop a coin down the defrost while we were waiting for my boys to get out of school.
Everytime I turn or slow down, I can hear it rolling around and it's driving me absolutely nuts!
What's weird though is that if you're sitting in the driver's seat it sounds like it's coming from the passenger side, but it's the opposite if you're sitting in the passenger seat. That's why I think it was dropped in the defrost.
Anyone have any tips on getting this out?
Ugh...
You really think I'll have to break it down that much to get it out?
I can do it, but I'm sure not looking forward to it lol.
I was being a smart@$$ more than anything. But if you can't see it to get some kind of tool on to grip/pinch it, not sure what other option you have.
I did take all the vents out the other day to see what I was dealing with and I'll definitely have to get a vacuum hose and try that way.
My mother-in-law has a really flat vacuum hose she uses to vacuum out the lint from her dryer vent that's inside the dryer, not the the one leading outside. That's a pretty narrow opening, so maybe I'll have luck with that. I just don't know how long that hose is.
Edited by njs2247
Different but similar, I share only in case your ending mimics mine.
In the day, my little daughter dropped a plastic Easter egg in the port on the back of one of my Klipsch speakers.
It required professional removal.
Been there before. When my son was 1, he dropped a toy down the port on the back of my subwoofer. Fortunately I was able to take the amp off the back and get it that way.
I would try taking the truck off a huge jump, the temporary lack of gravity might cause it to float up
Only logical idea I can come up with also haha.
Sent from my SAMSUNG-SM-N920A using Tapatalk
do you have any way of fishing a magnet down the vent and hoping the coin 'sticks'?  i've got some "rare earth magnets" and man those suckers are strong!
i figured before i posted this that i actually try this with some coins...  all my canadian quarters and dimes worked, 1 nickle did and one nickle didn't.
i only had 1 american coin kicking around  - a nickle and it did not
I'm pretty sure American coins aren't made with enough metal for a magnet to work.
When I was a small child, I was playing with a marble on the dash of my grandmothers new 1970 Impala. Well eventually it found its way down the defroster duct. That damn thing rolled from one side to the other every time you turned a curve for the next 18 years......
You might get lucky and try accessing it through the cabin air filter and /or blower motor. I would adjust the defrost/heat/ac location settings hoping it would work its way to the bottom. If that doesn't work then you will have to start pulling the dash....
    • IMNTBHO;  the worst thing for the 6L80 is to be lugged down to low engine rpm while in high gear......AKA, to save fuel.   I rarely use D on my '16 with the 6L80 and use M mode to keep engine RPM above 1500 at the speed I'm driving, which is also benefiticial for the tranny because line pressure is kept up because the pump is actually turning a decent speed, and it's not always hunting to drop to the next gear to lower the engine RPM's.   Never above 30mph.............M3, maybe M4 if just driving thru a small NoDak town Never above 40mph............M4 Never above 50-55mph.............M5   This is way better for the tranny and the engine.........especially if AFM is still active.   262K miles on my OEM 6L80 as I type this.
    • If they had nuclear material for "11 nukes" we'd have seized it.    Our military has been rendered either too weak/dumb to seize it, or they don't have it. Your pick,K-nut. Because right now we're fighting over who gets to toll oil tankers in the strait.    I hope you're man enough to admit you've been taken for a ride when it's finished.
    • I hope you’re man enough to admit that you were wrong when it’s finished.
    • And you're obviously full of it too.  Apparently anything he does is perfect to you.  Don't you think this whole ordeal would have been better if he had maybe thought it all through first before bombing Iran at the request of his bffs in Israel, Saudi Arabia, and Qatar?  They are the ones that had the biggest issue with Iran.  Thus they have been pouring the platitudes and giving gifts/bribes to him.  Had he thought about the consequences of what would happen to the Strait before starting anything, we wouldn't have this issue.  Now he is stuck with no way out of this mess.  But you have your head stuck way deep in his rabbit hole to see anything else.  So no, I don't have TDS.  I see what he is.  The derangement is yours from no oxygen in the rabbit hole.
    • Bringing of the fact that every President has said the same thing. They can’t have nukes. I guess you missed that before epic fury they said they had enough product for 11 nukes and weren’t giving it up. That not political or polarizing. The opposition of that is and giving aid to the enemy. The mandate is decades old through many administrations. The difference is TDS.
