I was looking at going down to 18’s or 17’s. I have enough meat on my 20’s that I have not had an issue off-road. The Toyos are 34 inches tall.
  • 4 months later...
On 2/20/2018 at 7:42 PM, swirvn said:
I didn’t like the look with it completely off so I cut it in half. Best of both worlds. Still has the finished look but isn’t dragging on the ground like the stock one looks.
I just took it off and cut it along the seam and reinstalled.
I had my valance off for a while now and been wanting to do this. Finally got a Dremill and cut it in half. Looks a lot better than having it totally of in my opinion.
Looks good, when I had my 14 Sierra this is exactly what I did to it... On my 16 Silverado there is still a lot of plastic left once the air dam is removed so no cutting required...
one of the first mod's i did... air dam removal!!!.. looks good guys... gives allot more clearance
I cut mine in half as well! I prefer it but both ways look good...that is off and halved, but not complete. Complete it looks like a ground effects kit
Sent via Morse code
Sent via Morse code
Sent via Morse code
Sent via Morse code
Totally agree, it’s the best of both worlds. Best mod I’ve done by far.
Does anyone still have their air damn? Im looking to test out painting one but do not want to test it out on my current one. Will buy and pay for shipping. GM wants a little North of $200 for a factory one...
I just took mine off, a day after driving the truck home from the dealer.
Where are you located?
Im in Ohio
Im in Ohio
I’d prefer not to ship internationally. Sorry.
  • 3 years later...
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,588 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
