New to the forum and I'm sure this has been asked before, but I've searched and couldn't really find an answer.  I have 15 silverado LT 2500HD Z71 and do not have the off road page in my DIC.  Am I missing something or was this not on all 2500's?
If you have the "uplevel" DIC you need to turn this page ON thru the Settings option. See "DIC Info Page Options" in your manual. It's on page 5-33 in my '15 Silverado 1500 manual. I had to turn it on in my '15 1500 Z71. I assume a 2500HD would be the same.
Wow.  I have a 2015 2500 and I have never even looked for that in the DIC, that I know of.  Might not have it.  If I remember the next time I use the pickup, I will take a look.
My 2015 2500 LT has the offroad page on my DIC. Just had to turn it on in the settings section.
On 2/25/2018 at 6:36 AM, smith462 said:
I do not have that page in my 2015 2500HD either
Your's should have it available in the settings section to turn on so it will show in the info pages.
Redwngr,
I will look again, but mine is one of the early 2015s and may need an ECM reprogram in order to get it. I will look tomorrow to see if it is there
Z71/ Offroad package trucks will have it. Non Z / Offroad trucks i believe do not have it.
It was there in my 17 2500 LTZ 4x4 - no Z71 - just follow the instructions in the video.
If your build date is August 14th 2014 or prior, you wont have the off-road screen.  Built after that date it should have it.
Well that’s solves it my build is August ‘14 so I’m betting it’s before then.
    contrabombarde
    contrabombarde
  • Who's Online   0 Members, 0 Anonymous, 781 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
