Nor'easter
DONWT15
Got a bit of snow from winter storm Riley. We're 250 miles away from the Atlantic coast.
These pics are this morning after cleaning up twice yesterday and going back inside around 5 pm.:(
The yardstick is at 11 inches.  There is also a white Impala parked behind the truck.:lol:
My 99 looked just like that.  In fact I thought it was a 2019 model when I looked out the window this morning.  :)
We lost power around 2pm yesterday, not expected to be restored until 11pm on 3/5/2018...
We didn't get much precipitation though...
Glad I have a wood stove and generator...
Steve
2012 2500hd 6.0l
:thumbs:
We got lucky. Lost power for about 2 hrs.  I hope they beat that estimate.:(
I knew it was under there somewhere. Maybe third time's the charm.
It's amazing how much it can vary. The office I work at is near the coast and it was just heavy rain and winds. But places right on the coast got absolutely swamped with storm surge.
Don't worry guys and gals, Al Gore is on his way to give a speech on global warming.
Yeah, I'll stick with the snow. Really don't want to paddle my rusty butt to high ground.:lol:
Her brother lives near Syracuse and they had a foot of snow.. Meanwhile in NE Georgia we were sitting on the porch in 72F.. He sent pictures and so did we...
We went wheelin last night. Perfect conditions! 3 ft in some spots. Lots of big holes in the tore up detour around a landslide. Lot of fun!!
Yup, looking at 10-18 inches here by time all is said and done. Likely use the Wifes new Nissan Maxima and leave the truck behind.....even in 4WD, the Max is better.....the tires on this truck absolutely suck, and being a lease, not in a rush to replace them
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
