I put the Elite E2-X on my 2016 Silverado about two months ago.  Catches quite a bit, especially right now in these cold months.  I bought the upgraded braided hose and don't have any noise or collapsing issues that some have had with their setups. I also purchased some extra OEM PCV lines from GM in order to have OEM connectors that snap on/off the connections on the engine. I have a clean side separator, but did not install it and from what I've read, is not really necessary on these trucks unless you are pulling alot or putting your engine under a full throttle.
Some pics of my install:
image.png.fbc348f30adadaa926cfc92f623d0e76.pngimage.pngimage.pngimage.pngimage.pngimage.png
Nice install!  So 2 things:
1. did the bracket for the can come with the can itself, and did it mount using holes you had to tap?
2. Is that silver doohickey a 1-way valve ?
The bracket that holds the can came with it. I mounted the bracket to the brake booster (take off the nut holding the brake booster, slide bracket over bolt, replace nut).
Yes, the silver doohickey is a one-way check valve.  I bought the kit that included the valve and the clean side separator. Like I and others have said, you really don't need to install the CSS, and you really don't need the check-valve for these trucks, but I have it and decided to install it anyway now while I was doing everything else.  I may install the CSS later since I own it, or I will try to sell it.  IIRC, the entire setup from Elite Engineering with shipping and the upgraded braided hose cost me right at $400.
Do you have adequate space under the can to access the drain and put something under it to collect the garbage coming out of it?  How does it affect access to the dipstick?
That moroso would work great one a 6.0 3/4 ton, but the LT series in the 1/2 ton would need  a lot of additional plumbing.
3 hours ago, Mike GMC said:
That would mean that the catch can somehow is removing oil from the engine that was not already on it's way to the intake, or you engine has worn in a bit has a bit more blow by than it used to.  I don't see how the catch can could possibly suck oil out of the engine, so I'm guessing he latter.
So you're saying my catch can isn't catch about half a quart of oil per 5k miles?  Because thats about how much I dump out in that time frame.  Generally I'll dump it twice between oil changes.  I have no doubt these, or any, engine burns some oil, but I think most is being taken by the CC.
Some of that in the catch can is water.
Are you saying you dump a half quart out of your catch can, check your oil level and it's a half quart low?
Oil consumed by engines goes to one or more of the following places:
1.  Past the rings and valve guides and burned.
2.  Through the intake from pcv systems and burned.
3.  Out through openings and onto the vehicle or ground.
If your engine is very healthy and well sealed, most will come from the pcv.  As time goes on, a higher and higher percentage will come from the rings and guides due to wear.
My Moroso pulls a good amount of ugly juice out of mine.
Mounting was easy, but I hated to loose the space over the unused battery box.
It looks cramped in the picture but there is no problem with dipstick access or draining. I have a nozzle threaded to the bottom of the can and drain into a regular water/pop bottle with ease. I'll try to post pics of that tomorrow
  I am very happy with the E2-X on my 2016. I made use of all the factory quick connectors to the manifold. I did need to search for an adapter to get the CSS to connect to the intake tube (CAI specific). I find this mounting point easy to get a bottle or cup under the drain valve and I never get more than a few ounces maybe 6 at the most out of it.
Edited by vfm2010
I wonder if the can would fit there with the stock intake?  Would the supplied hoses be long enough to go around that massive intake silencer?
I got the UPR and it fits\looks OEM with a nice set of hoses with quick connects. Got the pro model and it catches enough to drain twice between oil changes. On the drain put a poly tube and run it down attach it near the front somewhere, Slide a drain pan under and open the valve. Doesn't get much easier than to drain.
    250.3k
    chfkief
    chfkief
  • Who's Online   2 Members, 0 Anonymous, 1,431 Guests (See full list)
    • Fred was in the fertilized egg business. He had several hundred young pullets, and ten roosters to fertilize the eggs He kept records, and any rooster not performing went into the soup pot and was replaced. This took a lot of time, so he bought some tiny bells and attached them to his roosters. Each bell had a different tone, so he could tell from a distance, which rooster was performing. Now, he could sit on the porch and fill out an efficiency report by just listening to the bells. Fred's favourite rooster, old Butch, was a very fine specimen, but this morning he noticed old Butch's bell hadn't rung at all! When he went to investigate, he saw the other roosters were busy chasing pullets, bells-a-ringing, but the pullets, hearing the roosters coming, would run for cover. To Fred's amazement, old Butch had his bell in his beak, so it couldn't ring. He'd sneak up on a pullet, do his job and walk on to the next one. Fred was so proud of old Butch, he entered him in the City Show and he became an overnight sensation among the judges. The result was the judges not only awarded old Butch the "No Bell Piece Prize," but they also awarded him the "Pulletsurprise" as well. Clearly old Butch was a politician in the making. Who else but a politician could figure out how to win two of the most coveted awards on our planet by being the best at sneaking up on the unsuspecting populace and screwing them when they weren't paying attention. Vote carefully in the next election, you can't always hear the bells.
    • Can someone confirm if the GM order workbench terminal is able to validate a custom build sequence:   1) Initialize the Allocation Base: Open a new vehicle build queue, select the 2026 Chevrolet Suburban 4WD, and pick the High Country (3LZ Preferred Equipment Group).   2) Select the Diesel Powertrain: Go directly to the engine configuration screen and choose RPO code LZ0 (3.0L Duramax Turbo-Diesel). Ensure it maps to the MHS 10-speed automatic transmission.   3) Deploy the Seating Swap: Navigate to the Interior Options screen and enter RPO code ATT to replace the standard captain's chairs with the power-release 60/40 bench seat. Because you are not trying to force a separate luxury or air-suspension bundle, the standard, premium D07 Fixed Floor Console remains active. The system will accept this change immediately without triggering a warning message.   3)Apply Heavy-Duty Hauling Capability: Input RPO code NHT (Max Trailering Package). The commercial terminal will automatically bundle the required trailering hardware and software modules to support the diesel engine's maximum towing capacity.   5) Layer the Premium Tech and Glass: Separately add code C3U (Panoramic Power Sunroof) and code UKL (Super Cruise) to the order screen.   6) Run the Final Validation: Click the "Validate Order" button at the bottom of the interface.
    • Spent the last hour or 2 googling and reading up on the spacer thing. I don't like the loss of thread contact on the slip on spacers, but it appears you can get "extended" lug nuts that reach into the hole of the wheel to get back the lost threads. Looks like the only true hubcentric slip on spacers are at least .375". I'd want as little as I could get away with and don't want to cause other clearance issues going any thicker. Bora seems to offer what appears to be a well made .375" spacer and extended lug nuts. I searched here and did find a couple threads recommending Bora. But not cheap. By the time I buy spacers and lugs, new TPMS sensors, then pay a tire shop to install the new sensors, I suspect I'm going to be in over $400. Thinking about running out and getting some washers to put behind the wheel to see if .375" is enough to clear calipers, turn lock to lock without rubbing, and to see if the wheels/tires look strange pushed out a little. This would just be to check fitment.
    • Roadmaster makes some quality parts; I have their sway bar. I considered the RAS, but I ended up bagging. I didn't know what kind of ride I'd get with RAS, and the bags have interior jounce bumpers, so I can run 0 pounds pressure. I figured I'd have the best of normal suspension ride with assist on-demand. But it seems you got pretty much the same in one item.
