^^ Nicely done!  This is the best and tidiest use of this space I've seen so far!
Replaced my cubby hole cover plate with the trailer brake cover plate. Then cut out opening for my light switches. Trailer brake cover plate is flatter and accepts switches better with a "factory" like look.
I like that trim. Is it wrapped?
Sent from my SAMSUNG-SM-N920A using Tapatalk
Thanks, no it is a process called hydro-dipping. They take a tub of water, then lay the graphics on top of that water. Then they dip the plastic piece into the water and it adheres to the plastic. I'm sure its a little more scientific than that, but that's the simple explanation.
Ahh dipping, looks very good.
Thank you Sir, appreciate the compliment.
Put the slider there for my Hopkins insight 2 brake controller... All these dang trucks should have factory brake control...
I agree but I get why they don't.  I had an aftermarket installed several months ago while my truck was in for service.  We are pretty sure we are going to buy a travel trailer this spring.  If we do buy one, it will be the first time I've needed a brake controller since 1989.  I am guessing there is a lot of people who have factory brake controllers that are never used.  Many like me have pulled a lot of cargo or boat trailers but they either don't require brakes or use a surge control.
Aftermarket backup sensors and light bar controller. I replaced the original with one that didn't have the cubby and custom cut it to fit the switches.
Yeah I am with you, I bet lots of people do not ever have a need for the brake controller and quite frankly the Hopkins controller I have is just about as good as factory, just doesn't look as clean... I just wish GM made it easier to add the OEM controller but, I am nit picking here lol...
where did you get the cover plate?
GMPartsDirect  Part# 84109447
I put my phone holder in there, with some modifications to make it fit.  I have a few pictures of it, in progress, but none of it done.  I'll post some complete ones tomorrow or Friday.
Good ideas for that space! I like the clean look.
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 281 Guests (See full list)
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
