This is proving very difficult to find!  Even the local 4 Junk yards...  why is this?
I need black leather 2016 or 2017 center console to replace the jumpseat console.
Craigslist, Ebay, offerup, any of the many gm parts websites, gm dealer.  gmpartsdirect.com seems to be a popular one.  car-part.com is also popular for salvage ones.
 You will need a custom harness, to go a long with console.  You can get that from a member here.  His name is @pgamboa. Good luck hope you find what your looking for. Also check out these threads, if you haven't already.
Edited by 2017_whitez71
1 hour ago, 2017_whitez71 said:
@pgamboa
Yes sir!  Precisely why I want to get one!  LOL!  I've read through his entire thread and watched the videos.  It looks super nice and that's what I wanted, but didn't want to drop the additional 40k for the center console!  (so I exaggerate).
But yes, this has me jones'n do do this!  Just need to find a console! :)
Thanks!  will keep you posted!
@2017_whitez71GMPARTSDIRECT.com....you will have to piece it together but I just did this and got everything I needed to swap my jumpseat console out for a full console.
Edited by Lsufan03
Thank you for your help!!
Would it be possible to get a screen shot of your order?  There are a billion and a half parts there to order... yikes!!
PM me if that's better.   What was your end cost?
keep an eye out at junk yards. use Car-part.com and search there. Don't just jump to the console option, look at the trucks that say they have jumpseats as well. I found a Cocoa console from a 2015 that i used in my 17. i only have $265 in it shipped.
jacobrmiller05 good call!  I will keep the search on.
  • 6 months later...
4 hours ago, Vinnie Cantacessi said:
  I have an LTZ center console brand new either for sale or trade for a black leather jump seat
How much and is it a charging console? I know a local guy that may want it
4 minutes ago, Vinnie Cantacessi said:
Yeah it is the charging console lid. Does he have a leather jump seat by chance?
Work truck jump seat.  I dont think any trucks came with a leather jump seat. only work truck grey or LT black
Edited by Nasty
1 minute ago, Vinnie Cantacessi said:
Yeah you can get a bench seat in leather. That was the other truck I was looking at.
Ive never heard of a leather jump seat.  But maybe ill try to find one and trade you
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
