Any further updates? Part numbers of lights and such? I am also wondering about how many lumens the light bar is...
Edited by 6.2Midnight
The RC kits are 12000 lumens for their 30” curved single row light bar.
16 minutes ago, 6.2Midnight said:
Kinda my point...
Not sure what you mean by this, but I consider it a move in the right direction.  The last time I inquired several months ago, they said there were no plans.  Today, he said they are working on a kit specifically for active shutter vehicles but it is not available for purchase yet.  So, I'll take it!
Who did you talk to? I called today and they said there are no plans to make a kit for trucks with the active shutters.
Sent from my SM-G950U using Tapatalk
Guy's name was Kirk.  He straight-up said they were developing a kit for our trucks but it wasn't quite ready for release yet.  Probably full of &#$*.
Soooooo, sounds like I'm going to have to break out the trusty Dremel and do work!
Guy's name was Kirk.  He straight-up said they were developing a kit for our trucks but it wasn't quite ready for release yet.  Probably full of $*.
I just scrolled up after I posted that and saw his name. I'll call tomorrow and ask for him. Maybe I'll get a different answer. I'm trying to avoid the dremel lol.
I just spoke with someone at RC. Didn't catch her name, but she did confirm that they ARE making a kit for trucks with active shutters. Like said before, there is no ETA.
Did you think I made it up?  ?
  • Haha 1
Did you think I made it up?  [emoji23]
Lol nope. Just think it's funny that I talked to 2 different employees there and 1 says they're not making it and the other says they are.
Plus companies will tell you they are making something just to keep you as a customer. Sometimes, they will take that idea, bring it up as their own to get credit from their boss.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
