Blackbear tuning- 2015 silverado 5.3l
Currently with 6.5" lift 20x10 and 35s i get about 12.5mpg.
When i pull my rzr on my 14' tandem axle steel trailer i get about 8.5mpg.
Im reading alot that the blackbear tunes is the best bang for the buck... coming in around 260 plus the core charge.
Im looking to improve shift points, throttle responses and get 2 to 4mpg better at minimum.
I kind of would like the option to change to economy tune etc but that cant happen with just the blackbear right?
Sent from my SM-G955U using Tapatalk
Blackbear Perfromance is the way to go.  I know they can really wake up our trucks.  They did on my 2002 Silverado and technology has changed a ton since then.  Now that these engines are direct fuel injected I'm sure they can do even more.
Not sure if you can get better economy but contact them and see what they say.  To me it is well worth the cost.
I'm getting 15mpg in the 02 and when I tow our 20' enclosed tandem axle trailer it gets knocked down to 7mpg.  But then I only have a 5sp transmission and I do have 3:73 gears.
You aren't going to get much better mpg (especially not 4 mpg), if mpg was a concern you shouldn't have lifted. One thing you can do is get the rear end up where it should be just above the front end based on your sig pic. That will help with aerodynamics, the whole useless cali lean just makes it worse for mpg, towing/hauling alignment and others on the road with your headlights blinding everyone.
Tyler
Tyler
How do you figure? My roommate put a canned tune on his dodge with 35s and 20x12s and he most definitely got a good 3 or 4 mpg gain. Im not asking to get 20mpg, im looking for a solid 14 or 15.
Sheesh its not cali lean. It barely sits higher in the front. Its a store bought 6.5" lift.
You will not get the 2 to 4 MPG increase with any tune even if you keep your foot out of it.  If you want to increase fuel mileage I would re-gear the truck first then get the tune to alter shift points.  I have a Blackbear tune and didn't see hardly any improvements on fuel economy. I do however really like the truck much better with the tune with the shift point improvements.
Then how did my roommate see an increase? I dont think he ever hand calculated it, just went off what his dash read.
He also put exhaust and a cai on it. Which i will probably do..
Youre comparing apples and oranges, ram is a whole different truck no need to explain that
i have 35" on my 5.3l 6spd with exhaust cai and blackbear tune and get 13 OA mpg, if im easy on the pedal i see 15, and thats with 3.42 gears...
if you do want better mpg (econ tune w/ BB) expect to not have the power to tow that trailer and get increased mpg haha
I just installed my BBP Autocal tune and love the responsiveness and shift points.  This is how our trucks should have come stock.   If I stay out of the pedal,  I think it could be possible to save a little on gas, but not much.   By the way, using the Blackbear Autocal, you can swap from Eco to Mod tune in a matter of minutes.
Did your roomie correct for tire size change with the tune also? Could account for MPG change somewhat
Cant go off what the dash says when tuned.  I had a 2012 Duramax tuned and the dash said I was getting 19 MPG but hand calculated was 15 MPG.  Better to hand calculate when tuned.
And that's what i told him. But he never did. I figured since he typed in the tire size it was relatively accurate
We would tune your vehicle via our AutoCal. We can help improve shifting, throttle response, along with HP and TQ gains. With that vehicle it is usually on average 1mpg improvement. It depends on fuel quality, octane, and condition of the vehicle prior to the tune.
  • 1 month later...
I recently emailed them about my 17 Sierra 5.3, its seems like GM changed something and there's nothing BB can do for our crappy 8spd shifting since they say its locked by GM. With that said, what's to be gained on a newer truck like mine? Only mod is MF catback but will add a CAI before and if I do a tune.
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
