18 hours ago, MaverickZ71 said:
That 1984 shot looks like an F15 Eagle, being retired Air Force my ears perk up when I see military aircraft.  Worked around so many war birds I could name the plane by sound.  If that's a F15 Eagle, it wasn't capable of landing on an aircraft carrier, no tailhook on the rearend for starters.
  • Replies 3.3k
Top Posters In This Topic
On 12/3/2024 at 5:51 AM, Grumpy Bear said:
I didn't open the link. The page wanted assurance that I was over 18 as "Information of a Sexual Nature" may be present. I found that repelling.
Same for me. But I did click on it anyway. 🤣
  • Haha 2
That's an F-14 Tomcat - or supposed to be :)
Edited by oldKarl
  • Thanks 1
It’s a F35
That 1984 shot is a Grumman F-14 Tomcat, star of The Final Countdown and Top Gun movies.  The now-retired Tomcat was then the US Navy's counterpart to the USAF's F-15 Eagle, a role now filled by F/A-18 Super Hornets and F-35B/C Lightning IIs. And yes, the Eagles and Vipers do have lighter-duty tailhooks they can drop, but for emergency landings and engine tests only.
2 hours ago, customboss said:
It’s a F35
The top (2024) aircraft is a Lockheed Martin F-35C.
The middle (1984) aircraft is a F-14.
The bottom (1944) aircraft is the best fighter of WWII, the Vought F4U Corsair.
Boy, have you ever opened up a can of worms from fans of the WWII warbirds!
  • Haha 2
 Gummin Northrup P51 Mustang 😉 OR....
 A-36A-1-NA "Apache"
A Mustang on Crack
The A-36A Apache Attack/dive bomber version of the P-51 Mustang ...
Edited by Grumpy Bear
The first P51's that the US shipped to Britain were equipped with the Allison V-12's. The Brits were quick to realize that they would have a very potent fighter once they slapped the Rolls-Merlin in them. Subsequent P-51's were equipped with the Packard-Merlin. I always wondered what the performance characteristics of the P-38 would have been if equipped with the Packard-Merlins rather than the Allisons. A much higher ceiling for one I would suspect.
The local HOA sent this homeowner a letter saying that they need to have a fence blocking their trash cans from view.
Seems the homeowner has a special message for HOA Karen! 😂😂😂
  • Thanks 1
  • Haha 2
 A-36A-1-NA "Apache"
A Mustang on Crack
North American Aviation built all of the P-51s, in CA and then TX.
Legendary Lockheed engineer Kelly Johnson wanted to test Merlins in a P-38, but the Army Air Force said NO:
1) It had already been disappointed by the relative lack of performance from putting a Merlin in an older airframe (the P-40)
2) A high ranking USAAF officer (a former GM executive and still a big stockholder) had lobbied heavily for the Allison engines in the P-38. Allison was a GM subsidiary.
3) New P-38 squadrons were already being sent to the Pacific over the ETO, where the hotter tropical temps and lower altitude dogfights were more agreeable to the turbocharged Allisons.
4) The USAAF had already chosen the P-51B/C as its long range escort fighter in the ETO, for its higher speed, longer range, better performance at altitude, and favorable logistics. Packard was strapped with Merlin production as it was, and 2 Merlins could equip 1 Lightning or 2 Mustangs. Everything in the ETO was a race to beat the Nazis before they could equip their wonderweapons with nukes.  Finally, Mustangs sipped fuel, and a Mustang required half the maintenance of a Lightning.
  • Thanks 1
I brought receipts.
Results from the 1944 Fighter Conference:
(1 is best)
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
