On 5/22/2019 at 5:50 PM, Will O'Daniel said:
Due to recent uptick in interest. I am posting the pricing on here. I have a 2-3 week build time per unit. This is just a hobby and I am more than happy to help anyone with getting their truck to the look they want it. I am in the process of designing and building the 2500/3500 series hidden which setup.
I use 1/4 inch steel. I can pre drill all the holes but we have found that the factory holes and frames can be off by as much as 1/4 inch. It is best for you to drill your own holes in the brackets and plates. This setup does require you to drill 2 holes in the frame of the truck. One on each side. And drill out the threads to the rear of the tow hook nuts. I provide all nuts, bolts, and washers in grade 8. The front factory tow hook nut and bolt will be reused. All bolts are 1/2 inch thread. I also provide the snap brackets and bolts for the front license plate cover if your state required it.
Plate, brackets, and fascia bracket: $450 includes shipping
Plate, brackets, and 2” receiver: $475. Includes shipping.
THIS is the thread that I joined the site for.
I just picked up a '18 Silverado and I need to know EVERYTHING!!
I'll send you a PM with specific questions.
  • 3 weeks later...
31 minutes ago, JARED SCHROEDER said:
I was wondering if there was any update on the bracket for the 2500/3500's?
We have some brackets worked up and I am waiting for the plates to come in so I can test for them this upcoming weekend. We should have a full update in 2 weeks time.
On 7/3/2018 at 6:02 PM, gixxerk8 said:
Do you do this kind of work for a living or a hobby.  If a living, I would be interested in talking to you about doing another one.  I'm in Southern Oregon.
Will, I met the son of one of your customer's (gixxerk8) this week.  I have a '15 1500 LT and I have wanted to add a winch but don't like the kind that stick out. I would like to install one of your winch mounts with receiver because the hidden look is great. How do go about placing an order?
I sent you a PM.
Very slick looking set up Will.  The build specs on your truck make it a very impressive and capable rig.   Keep up the good work ?.
  • Thanks 1
Wondering if you had a chance to test the brackets out?
Is this setup your coming up with for the gas or diesel?
Cheers
Edited by JARED SCHROEDER
Cheers
I have got a bracket built. I will say it’s not a a successful build as the original bumper fascia cannot be used without reducing ground clearance. I used a badlands winch,  which has the lowest mounting height available on the 12,000lbs market. This is the same case with both diesel and gas. The transmission cooler would have to be relocated and the engine skid plate reduces available room as well. I am sorry  I couldn’t accomplish this one.
Thank you!
  • 1 month later...
31 minutes ago, J_Mas6.2 said:
have you tried this on a 2015 by chance?
Yes sir! It fits 2014 through 2018 1500’s.
  • 1 month later...
I know I am a bit late to this party. Do you have any pictures of the actual bracket used for the rear winch ?
    Joegstfsn
    Joegstfsn
  • Who's Online   4 Members, 0 Anonymous, 636 Guests (See full list)
