I have a 2014 Silverado crew cab I’m wanting to do a conversion to the 2016 model I really like the way the front end on that style truck with led Day time running lights beside having to buy the obvious things does anyone know would the fenders on the 14 work and how bout the radiator support will mine work ? Any info would be appreciated
IMG_1596.HEIC
Just sold this “16-18 front end conversion kit” few weeks ago., I should have another coming in the next week if you interested. The only thing you’ll need be the headlights plug and play from gen5dyi.com to make your 14 connector fit with the 16 headlights IMG_0301.JPG
I did this conversion to my 15 Silverado
IMG_1596.HEIC
Just sold this “16-18 front end conversion kit” few weeks ago., I should have another coming in the next week if you interested. The only thing you’ll need be the headlights plug and play from gen5dyi.com to make your 14 connector fit with the 16 headlights IMG_0301.thumb.JPG.958f8309eec4ed3720d565448a39892a.JPG
Man that’s nice was it hard to do ?
Not at all with my kit is all bolt on, 4 hrs max
That’s nice
20 hours ago, Viktorrocks15 said:
IMG_1596.HEIC
Is that the same truck in both pics?
Wanting to do the same thing with my 15, love the look of the 16,17,18s. Thought about trading mine in for an 18 but if I can just do a conversion like this it would be better. Same on wanting to know the price
I like 2016-19 Silverado too; however, I just want to caution you before you are going to do it. If your 2014 Silverado has part of front end damage that needs few parts replacement anyway or it has a rebuilt title then I might consider do the conversion. Other than that, 1) if you have a clean title, you might have a hard time convincing a prospective and suspicious buyer that your pickup has all original part and paint or has never been in an accident. 2) your 2014 parts have used resale values. 3) unless the 2016 parts are real cheap, I would use the money from not doing the conversion to lift/drop with a really nice set of wheel and tire plus other modifications to make your 2014 uniquely your. Someday, who knows you might get bored with your 2014 then you might consider 2023-2025 generation looks. In my opinion, think twice because it might not worth it.
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
