I use a popsocket thin mount stuck to the smooth part on the top left of the radio just to the left of the dash. I can easily glance at it while using my GPS. I have the power cable routed down the side and plugs into the usb for the radio.
On 9/1/2018 at 5:09 PM, Ravenkeeper said:
gallery_151133_4800_1249650.jpggallery_151133_4800_109700.jpggallery_151133_4800_1736367.jpg
Had my phone mounted here.  10’ power/data cable, suction phone holder trimmed down, and was about to put a bolt, washers and nut in to better secure it.  Had I installed the bolt, washers, and nut, it would not have fell out of the pocket during my accident.  Looking at reusing this phone holder if my next truck does not have the brake controller installed.
I see you are also part of the Blue Card Mafia...hehehe..
I use a QuadLock mount with a suction cup attachment to the right side of the radio bezel since I don't have heated seats.
In my BMW, I use one with a power head since I connect to the radio through a bluetooth adapter - it's a 1990, no choice - I keep it original.
I don't need the power head in the truck because I still have to plug the phone in for Apple CarPlay - tried C2Play2Air, it wasn't good.
QuadLock has many options - I have one on my bike, one on my arm band when I run and a few desk mounts with the charging head. All you need is the case and it works with all of the mounts.
For me, it works awesomely!
I was looking at getting a quad lock but I’ve gotten accustomed to using the pop socket. Might change in the future. I do like the versatility of the quad lock and the different mounts and security of each one.
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
    • What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.    The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way too big headlights (similar to a previous non-Wrangler SUV) should include dual round headlights like the early version.   If not this would look OK   At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.    I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crossing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
    • I saw this news earlier this year:   https://theautowire.com/2026/06/12/gm-kills-off-chevys-biggest-silverado-trucks-as-sales-collapse-and-factory-fallout-spreads/
