What and where are you guys using to mount your phone in the cab? Looking for some pictures of setups! Include links to mounts if you can also!
I used to use a magnet mount that used the CD player. Found it blocked the hvac controls though. Switched to a pop socket vent mount. Its ok. Jiggles more than I like.
Edited by Roscopcoletrain
I had one of these:
https://smile.amazon.com/gp/product/B01BZC262Q/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
*EDIT* Looks like there's a newer model getting good reviews for durability over the old one:
https://smile.amazon.com/iOttie-Dashboard-Windshield-Samsung-Smartphone/dp/B076B27WP6/ref=dp_ob_title_wld?dpID=51EXcNKQgoL&preST=_SY300_QL70_&dpSrc=detail
Nice mount but the bouncing of the truck eventually wore the joints out and the suction cup has a gooey material on it to make it stick better.  When you remove it, it leaves some of that gooey stuff behind and it's a real pain to get it off of the windshield.  If you go the route of something like this, DO NOT put it on your dash, it discolors it permanently.
Edited by Darmichar
I had one of these:
I’ve got a very similar one but mine charges wirelessly. I have it hard wired to the truck so I just place my phone in and it charges. I’ll work on getting pics later.
Our dashs are really high up, I dont like the idea of the sticky stuff on the dash? I use my phone alot for just the waze app so I can see traffic..
The one I posted above I had mounted at the top of the windshield so my phone was in landscape right next to the rear view mirror.  It was actually a very nice mount but the roads around her wore it out over the year and a half I had it.
I've been using this simple magnet mount for a few weeks now.
Magnetic Car Phone Mount, APPS2Car Universal Stick On Rectangle Flat Dashboard Magnetic Car Mount Holder for Cell Phones and Mini Tablets https://www.amazon.com/dp/B077GSPW9N/ref=cm_sw_r_other_taa_1UQGBb6QE5FGA
Strong magnet and extremely low profile. The radio bezel is tilted slightly towards the driver which is a perfect viewing angle for the phone.
And yes, thats a blackberry!! (Don't be jealous)
9a5f654d8398b6d78f63f1daab457910.jpge3deb1183f81b07a9ef767e2559e6a7c.jpgf0f66f24e44ca7c0f1ddc5a60456418c.jpg
Sent from my SM-T700 using Tapatalk
  • Haha 1
I have Pro-Clip's in both my car and truck.  On the truck it's slightly over the passenger vent but it doesn't block much air or anything.
I like the magnet mounts in most of my cars, but every place in this truck that can work seems to block a vent...not an option in Texas heat.
Is have the floor console that has built in cell phone holder up by the power ports. Then I run a charge cable from inside the console to phone. That way I don't have to much excess cable laying down in tray and keeps all the ports up front open and clean. The if I need to see the phones screen out maps I use andriod auto and project to the radio screen.
Sent from my Pixel XL using Tapatalk
Does anyone have a picture of the Proclip prior to installation?  I have no problem paying for a good mount, I just want to see what it is.
You can see some pics on their website.    You have a choice of mounts which you slip into the gaps in the trim and then depending on your phone size you choose a device holder.   In my case I have the Angled Dash Mount (for the right side).    It comes with 3m double sided tape, but it holds fine without it and  I've never felt the need to actually use it in any of my cars going 10+ years back.
https://www.proclipusa.com/vehicle/dashboard-mounts/9734-chevrolet-silverado-1500-series/2018
My last truck had a phone holder that slipped into the CD slot. A year later and it’s still sitting in the glove compartment of the new truck.
With CarPlay in the new truck, I rarely look at the phone anymore. I plug it in and usually just throw it in the storage compartment.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
