2019 6.2 emblem
Any one working parts that would have the part # for the 2019 emblem?  My local store has a blank look since I do not have a vin number. Thanks in advance.
On the same page, does anybody have a part number for the new Z71 emblem that's on the upper quarter panel on the new 2019's?
Is there a 4x4 or Z71 sticker for the back quarter panel on the 2019?
Yes. See Pic.  Decal for 4x4s, Emblem for Z71.  I do not have part numbers.
  • 3 weeks later...
  • 3 months later...
Got these ordered from my local dealer for $8 each instead of the $25 ea on eBay. Online GM parts stores have them for $5 but shipping charge is ridiculous at $15 for 2 emblems.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
