My passenger side mirror wouldn’t unfold with the fob or the switch on the door. So I manually unfolded it this morning. I’ve tried re syncing it but that hasn’t worked. I sprayed some lubricant in the mirror also. Can the motor be bought separately or do I have to buy a new mirror. This is a 2015 HD
Edited by CruseMissle
I used to have a 2014 GMC 1500 AT, I now have a 2017 GMC 1500 AT.  On both trucks, the passenger side mirror would only power fold when it felt like it, about 1/3 of the time.  Sometimes I could just hit the button a couple of times and then it worked.  On the 2014, I took it back the dealer and because it was intermittent, he couldn't find anything wrong with it.  So yeah, strange stuff.
These motors can be purchased. I looked into it at one point when my passenger mirror motor failed after about one year. I had it replaced under warranty though.
Have you tried to re-sync (reset) them? ...like if one is manually pushed in and now they are out of sync. Don't know if this will help with your problem, but it's always worth a try before replacing a motor...
The reset process seemed relatively...but I can't remember if I saw it on this forum or the Duramax Forum? Or, possibly it's in the owners manual?
Edited by EJCarter
Disregard - just re-read the original post and re-syncing was already tried...
I had a similar problem, and had it replaced under warranty. At first GM/dealer couldn't reproduce so I send them video.
Sent from my XT1585 using Tapatalk
Here is one mirror parts example: https://www.gmpartsdirect.com/auto-parts/2015/gmc/sierra-2500-hd/slt-trim/6-0l-v8-gas-engine/electrical-cat/mirrors-scat
It’s making a nasty noise I’m assuming something is broken inside. It won’t reset either. Looks like I’ll be buying a new mirror soon
Contact this company:
http://www.gruvenparts.com/gruvenparts-com-strengthened-spur-gear-for-2007-2014-gm-trucks-folding-mirror-assembly/
This motor is for an older model, but the page says 2015+ coming soon. Who knows when that was, but maybe they can help you.
EDIT: Here you go. Says it's a pre-order.
http://www.gruvenparts.com/gruvenparts-com-strengthened-folding-mirror-gear-for-2015-gm-trucks/
Edited by 8lugCT
Thanks I’ll look into it.
I called them, if its for the towing mirror, they have the replacement gear only but its not really listed.  Just email [email protected] and he can sell you replacement brass gear section to replace the stupid plastic thats failed.  Its cheap and its probably all that is wrong.  These towing mirrors are stupid expensive and mostly good except this.
Actually, this doesnt sound like its a tow mirror.  It is the same gear and motor used in the 2007-2013 trucks, it just has a slightly different housing.  But the link I gave you above would work for 07-13 power folding gears.
  • 4 months later...
  • 5 years later...
How do you replace the motor and gear?  Can't find any instructions from Google.  Thanks
Yeah so my passenger side mirror wouldn’t fold out. Pushed button again usually works   But this time, with my 63 yr old friend and 5 yr old child in the truck!! The damn thing caught on fire started smelling & smoking!!! I jumped out dumped my cup of what was mostly ice on it then grabbed this man’s hose turned it on ran to my truck & sprayed the heck out of it. I was in the middle of south ga so I needed it to get back on the highway. Thank fully the cameras worked so I could change lanes a tiny bit safer & finally home around 11pm. They want $1,425 to replace it. It’s just the motor is there a recall? What can I do? I’m in a huge bind with other unfortunate events simultaneously occurring (hence the over emotional tone above). I’m still trying to find a job on top of this. Can anyone help me get one win?
2021 Chevy Silverado 2500 high country so just fell out of warranty
Edited by Mdymdskppr
Model year correction
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
    • 185k on original 6.2L engine and 10 speed. 6" lift with 35" tires. Changed oil (Mobil 1 synthetic) when truck told me to. Original tranny with original fluid and no service or flush done. All highway miles. A/C compressor replaced at 155k. Oil cooler line replaced at 180k. Still daily driver. Love this truck.   This is my 3rd 6.2L vehicle (2008 Yukon Denali / 2018 Cadillac Escalade) with over 150k miles and no issues. Denali had broken motor mount at 100k.
