Denali Drivetrain noise when in AUTO
I have about 73K miles on my Sierra Denali and have recently developed a whining noise when I have the transfer case selected to AUTO.  Has anyone else experienced this issue, and determined what the cause is?
Mine has been like that since new. As far as I know every 4auto truck makes the noise.
Run it on a lift in four high and check the front diff. We just did two more last week. Pretty common on the 1500's. If you hear the noise from the diff drain the oil and check for metal.Hope you have extended warranty.
Mine hasn’t always made this noise, it just started. I’m going keep it in 2 high until I have time to get it checked out.
Check the fluids in the front diff and transfer case.
About how many miles are on the truck in AUTO? While auto can be used in all driving conditions without causing major damage to the vehicle, it does wear out parts, fluid, etc... in the front diff much quicker and will require more frequent service. If there are a lot of miles in AUTO, then a good place to start would be the front differential fluid as others have mentioned. The fluid is most likely oxidized/worn out and providing limited if any lubrication and the noise you hear is your gears or bearings wearing. If it doesn’t go away after a fluid change, then a trip to the differential shop or dealer is in order.
Mine has made a slight growling noise under accelerating since I purchased it with 20,000 miles. I drove it about 200 miles once towing in Auto on accident and with the AC on I didn't notice the noise on that trip.
My buddy bought a new 2016 new off the lot and his has the same noise since new.
Auto won't hurt anything, it serves a similar function as a full time AWD vehicle.
I really only use mine to get into fast moving traffic in the rain and for normal snowy driving. Also helpful on boat ramps because it doesn't hop around and bind up when you turn.
I was always a man truck kind of guy 4x4 lock or nothing but owning this I have found auto very helpful.
I'm planning on swapping both diff. fluids as well as the transfer case soon to see if this will help.  Any advice on what brands or weights that I should go with would be appreciated.
Condition/Concern
Some customers may comment on a high pitched whine noise from the vehicle noticed when driving in auto 4wd.
The customer may comment that it is an intermittent noise and no noticeable pattern to when it can be heard.
Recommendation/Instructions
The transfer case control module on these vehicles is located next to the accelerator pedal and is not covered by any close out or hush panels.
When the transfer case control module has to move the transfer case actuator motor the higher current passing through the module causes an "electronic buzz or whine" within some of the capacitors in the module that can be heard by some of our customers.
The latest transfer case control module in service parts has provisions to eliminate this noise. Replace transfer case control module with current part number in the catalog. When programming the module ensure that the description for the calibration installed states the following "New software (Version 9.2) to address field issue of setting DTC C0398 while being driven in AUTO mode for 1 hour due to the IPS sensor drifting."
Might have something to do with your issue, but you're still gonna want to service that front diff. It is not designed to be driven in Auto for long periods of time on dry pavement.
38 minutes ago, 2017Darkness said:
Condition/Concern
Thanks, that could be what I was hearing. The pitch of the sound would increase as I press the accelerator pedal and would quieten as i coast.
Yes it is, you will prematurely wear items out (Dif and T case maybe) but be design it wouldn't hurt a thing to drive around in 4 Auto on dry pavement.
My truck had the T case control module replaced because of the high pitched screeching noise. This noise only happened when it was directing power to the front wheels or shifting in and out of any drive mode. If you still have noise under deceleration this is probably not the issue.
 (From GMCs Website)
AUTOMATIC 4 HI
If road conditions frequently alternate between high- and low-traction areas, consider using the “AUTO” setting found on select GMC electronic transfer cases. This setting allows your GMC to automatically distribute torque to the front axle by anticipating the need for additional traction.  Shifting into “auto” engages the front axle, but the transfer case sends power primarily to the rear wheels in normal conditions and the clutches modulate torque forward to provide stability and enhance traction to the vehicle.  Although not always optimal for efficiency and wear of your vehicle 4wd driveline, AUTOMATIC 4 HI can be used on any road condition without risk of damaging your vehicle.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
