You have the bora 1.75 right? How much do they run?
Yup, like $125 a set. As long as you get a quality spacer you’ll be fine
Close to pulling the trigger on a set, the wheel tuck really bugs me.  I was unaware of the difference in track width but now that I know I can't un-see it.
Gonna order 1.5" for the front and 1.25" for the back.   I shouldn't have any rub in the front with the stock suspension and 20" wheels when using the 1.5" spacer right?
78.1mm / 3.08" the proper centerbore for hubcentric?
Do you have a lift or level?
no completely stock from factory with no plans to do either.
Someone correct me if I’m wrong but I thought the front stuck out .25” more then the rear on stock suspension?
That’s correct
Anyone know how much of the tip of the studs is not threaded? Also how much I can cut off and it not affect the threads/performance of the stud? Thanks in advance
ya i wrote the wrong thing.  I want a square setup.
I wasn’t questioning you I just didn’t want to screw it up myself because I’m thinking of doing something similar , only difference is I’m already flush with my fender with my offset in my wheel, I’m just trying to achieve a little more stance
I just ran out and removed 2 lugs of mine(one locking one oem).  There is 14mm between the top of the stud and the start of the first thread.
Funnily enough it took 14 turns to get the lug nut tight.  Therfore 14 threads of engagement is what is used stock.  I probably wouldn't go less than 10. (this is assuming stock wheels your aftermarket may be different thickness which will change the number)
What is the torque spec for the lugnuts?
I believe it’s 150 ft lbs. but you got me thinking, even tho it takes 14 turns doesn’t mean that you need all 14 to “hold” the wheel on, so let’s say mine met the wheel at 10 turns to tighten, does that mean that the threads before that are not really needed to secure the wheel properly? Or what am I thinking is wrong?
1 minute ago, FORGIVEN06 said:
I believe it’s 150 ft lbs. but you got me thinking, even tho it takes 14 turns doesn’t mean that you need all 14 to “hold” the wheel on, so let’s say mine met the wheel at 10 turns to tighten, does that mean that the treads before that are not really needed to secure the wheel properly? Or am I thinking is wrong?
how many threads of engagement is what is important and is what provides the strength needed.  I'm not quite sure what your asking.  There are unused thread at both the back of the stud(the wheel thickness) and the back of the lugnut(the part where the unthreaded stud resides once tightened).  That 14mm of unthreaded stud is useless and you can cut it off with no ill effects.  adding spacers essentially increases the thickness of the wheel and therefore more threads are covered and cant be used.
So take for example the lugs that come with bora wheel spacers are only approximately 1/2” long. So in theory if I have at least let’s say 3/4 of thread to use then the lug should be able to tighten to specs no problem. So if there is any more then “needed” then I could cut this off and it could still work? Or is there a reason that this could be in safe?
You can cut off any threads that come out the backside of the tightened open faced nut without affecting the strength.
The only real safety issues regarding spacers is
1. slip on spacers (the ones that dont have its own studs) these spacers essentially increase the thickness of the wheels and less threads get engaged.
2.  using adapter style spacers that are too thin.  When this style of spacer is too thin the factory lug nuts stick out past the face of the spacer and prevents the wheel from sitting flush against the face of the spacer.  This is the scenario when you would have to cut the stud so its behind the face of the adapter or the wheels need pockets on the backside between the mounting holes to accommodate the protruding studs.
3. Spacer out of balance.  The spacer is part of the rotating assembly along with the rims+tires.  If the spacers arent balanced you will have the same symptoms as your tires  being out of balance.  The only solution to this is to buy quality spacers.
4. Wrong hubcentric size.  If the adapter hub size is larger than the wheel it will prevent the wheel from sitting flush this is a very unsafe scenario.  If the adapter hub size is smaller you can get a hub ring to make up for the size difference.
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
