Viktorrocks15
Any chance on the new way saving the driver side window defrost piping?
10 minutes ago, JADSCOOP said:
I would go with Viktorrocks15 way of doing it . He is the one who built the first instrument hood for me.
Viktorrocks15 keep me informed on how your project is going
I may consider redoing my dashboard. Depending on how your turns out.
I have a black leather dash with stitching for sell if your gonna redo your dash ? HMU fr fr, just seen your dash is that high country brown orange
Edited by Frankielozano214
Viktorrocks15
I’m still in the beginning of it but I don’t think we can save the defrost vent pipe., it runs right in the middle where the hud Seats..
  • 3 weeks later...
Progress update.!
Finally had the time to do the pre-install work measuring and fitting HUD to our gen 5 dashboard frame and dashboard itself.
***Note***
After doing measurements i realize what I wanted to do wasn’t going to work then I went and go ahead a cut the dashboard which I didn’t want to do in the beginning and as I was cutting I found the solution in the mistake I made, making everything come together like I wanted. Cheers!!!
I know you all want is pictures so here the are..
5f2e0f8af819c0805ab5da04e4972e1a.jpg I know this dashboard was cut
But it won’t be once is finish since that’s not my dashboard, it’s the experimental one. But it’s sort of the finish product without the cuts.IMG_4821.JPG
Here’s the speaker cowl after I fitted and install the HUD trim. No glue used, HUD trim has pressure tabs that need to be cut in order remove and install. 682905eea6327134ab08433bde36ff61.jpg
Here’s the speakers tray, top one is the oem and the bottom one after fitting hud.
  • Like 7
Gentlemen, here’s the final product..IMG_4869.thumb.JPG.19dfc932fe5b134b4e3f8e8f2318fa4d.JPG
Dude that looks fantastic!!! Nice job!!!!!!
Thanks! Wish I could say same ting about my arm.. lol59079822259__E184D6E1-3397-4F0B-A117-C31B0E3A0F25.thumb.JPG.0f8d86f753871f4efe620d2a980661de.JPG
Hahahaha but was it worth it?! :) because honestly that looks factory!!!
Hahahaha but was it worth it?! default_smile.png because honestly that looks factory!!!
Thank you!!! It sure does look factory. Very happy with outcome. [emoji4]
That’s the spirit!
Congratulations. I am going to redo my HUD install now. Do you have a part number on the trim ring or tell us what vehicle it is off of?
  • Part # 22758784:  HUD Projector Trim Ring
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,307 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
