2019 license plate lights
smit303
  • Replies 64
On 8/26/2019 at 2:15 PM, Kozzy said:
All, I found some old T10/194 LED from a different project that I may try to use in the licence plate light socket. I am concerned about the "height" of this bulb.
Can anyone provide feedback on whether or not these will work? Is there enough room in the surround/capsule?
http://www.2040-parts.com/2x-t10-car-168-194-w5w-xenon-white-38-smd-led-wedge-side-turn-signal-light-bulb-i1059613/
On 8/26/2019 at 10:59 PM, Wheelguy said:
Says they’re license plate lights so should work since they’re also T10s. Just compare the length to the bulbs that are already in there. IIRC, the incandescent ones were 3/4 to 1 inch long. The area into which they go is pretty sizable for the bulbs. You will be able to tell quickly if there’s a fitment issue. Just very awkward for me to reach up there & turn on the driver’s side.
Just to follow up- they did not fit.. too long :(
Let me know who else on here buys a 10-PK and wants to hook up some fellow new-gen owners!
Anyone asking why LED 194s were not installed from the factory... they are not DOT approved lights.  If you look at your packaging, it should say "For off road use only" somewhere, because they are not DOT approved for road use.
Changed my LP lights out for Sylvania LEDs in about 5 minutes.  Looks a billion times better.
Figures - one would think a certain sized bulb would meet certain dimensions other than on the contact end.  Just as soon as I insinuate they should, they won't LOL.
  • 1 month later...
On 11/21/2018 at 5:10 PM, Pyrojodge said:
Thanks... heres what i used.  I was concerned that with the rear view mirror camera and back up camera they may flash but all is well.
Tail lights: AUXITO 912 921 LED Backup Light Bulbs High Power 2835 15-SMD Chipsets Extremely Bright Error Free T15 906 W16W for Back Up Lights Reverse Lights, 6000K White (Upgraded,Pack of 2) https://www.amazon.com/dp/B0728DYR9H/ref=cm_sw_r_cp_apa_7sE9BbH185JEP
License plate lights: AUXITO 194 LED Light Bulb 6000K White Super Bright 168 2825 W5W T10 Wedge 24-SMD 3014 Chipsets LED Replacement Bulbs Error Free for Car Dome Map Door Courtesy License Plate Lights (Pack of 10) https://www.amazon.com/dp/B071LHP5WP/ref=cm_sw_r_cp_apa_ouE9BbRCAANBR
I used these bulbs for my truck. Reverse lights are amazing. Tag lights won’t come on, and now the old bulbs don’t work either. Blown fuse? Doesn’t make sense to go to LED and blow a fuse, but something happened. Any ideas guys?
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 1,554 Guests (See full list)
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • As a matter of amusement I’ll leave this conversation with this. Do you beat the government average fuel estimate? Statistics are a guide to me. Not a rule. Someone once said I have to have the last word. If true and possible may be. I’ll blame that on working in a family business.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
